How much did you pay for your Lt1 Turbo set up
Old 07-11-2005, 11:48 AM
CONVERTED's Avatar
Default How much did you pay for your Lt1 Turbo set up
I"M curious to know what kind of prices i'm looking at from top to bottom on building my Lt1 for a turbo/ the kit....
if You dont' mind please post turbo kit cost and then any additional cost (engine work etc)
Also i'm looking to make this a daily... what kind of fuel econ do you get when your not boosting....
Lastly... what are running (PSI) and dyno #'s are appreciated... oh yeah timeslips...
Thanks in advance... PS i'm trying to track down total cost an LSx swap into my 95 and will make my decision after I've obtained enough info....
Old 07-11-2005, 12:47 PM
aggiez28's Avatar
ive got a turbo setup and turbo motr for sale, i also havea ls1 with wiring harness and pcm and tranny(a4) for sale.
email me if interested
brook
Old 07-11-2005, 04:22 PM
CONVERTED's Avatar
brook
how do you have all that???? pm me prices
Old 07-11-2005, 04:51 PM
aggiez28's Avatar
motor and turbo will be over 20k if your interested we can go into details. iim askign only 3500 for the ls1 with everythign
brook
Old 07-11-2005, 05:14 PM
CONVERTED's Avatar
brook
the turbo is for the LS1??
Old 07-11-2005, 06:50 PM
aggiez28's Avatar
3500 for the ls1 with 4l60e transmission. also includes computer wiring harness and accessories. manifolds with 02 sensors, motor mounts
if your interested email em
brook
Old 07-11-2005, 06:53 PM
aggiez28's Avatar
turbo is for an lt1
brook
Old 07-11-2005, 09:23 PM
whynot's Avatar
didn't cost me to much, fuel system was the most expencive part, unless you count the engine rebuild, since the stock lt1 wouldn't hold the amount of boost that the t70 would put out, it says 4.2 bar is the max output of the turbo, but I don't know what I hit, my gauge only goes to 30 psi, (I was runing 6 psi then the waste gate snapped shut and wow) that and it only held it for a second, then smoke and steam everywhere. But even with the complete rebuild and turbo kit I am only into it about 3k. The engine took up most of that too.
Old 07-11-2005, 10:06 PM
CONVERTED's Avatar
so engine rebuild, turbo kit and turbo about 3k???? what kind of numbers you putting down?
Old 07-12-2005, 10:43 AM
CONVERTED's Avatar
ttt please I really need help..../.
Old 07-12-2005, 06:12 PM
LTLHOMER's Avatar
How fast do you want to spend? I mean go?
Old 07-12-2005, 10:50 PM
n2oblkz's Avatar
Go to www.forcedinductions.com because they have PTK turbo kits for sale on there for the LT1.
Old 07-13-2005, 07:52 AM
RealQuick's Avatar
My homemade kit is going to finish running me ~$3400 for a homemade job. I have had access to a machine shop though and do all my own labor (assy, welding, etc.). I expect someone else that doesnt have access to a machine shop to spend~$3700 or so. I also bought my turbo used PT76 Q trim for $950 with only a couple thousand miles on it.
You could buy either a PTK kit (probably best on the market for LT1's), TTi street kit, or sts kit. Thats it for us LT1's that I know of. A PTK kit with a T70 will run you $5400 or so.
The engine, a forged short block will run you $3400-3600 (doesnt matter whether its a 355 or 383). You want heads too? thats another $2k. Cam, lifters, timing chain, etc. Lets call it $7000 for engine...
Tranny, if you have an auto, your screwed. That thing will blow up! The manual may last for awhile, but you need a clutch (Mcleod street twin seems to be best for LT1's). Thats ~$1000 with steel flywheel.
Fuel system? Aleast an intank 255 with BAP and large injectors (60's or higher). Your looking at ~$800
So, for a PTK kit, engine, tranny, fuel system are around...$14,200. I havent even talked about a rearend either...~$2400.
Old 07-15-2005, 03:24 AM
skinnies's Avatar
I have to agree with most of what your saying. I got a lot of money in my setup also.
Although, I say for the fuel pump situation, just get the racetronix dual intake 255 setup. I haven't priced it out yet, but I really only need the wiring because I have the two pumps and Y-block already.
Old 07-15-2005, 08:23 AM
RealQuick's Avatar
I was giving him a cheap alternative that would support support 600-700rwhp. If I had the extra cash I would dish out the $5xx for the dual intank setup...
Quick Reply: How much did you pay for your Lt1 Turbo set up
