diy meth kit
Old Jul 23, 2005 | 11:16 PM
Frost's Avatar
A progressive controller for this app could probably be home-brewed pretty easily... A surplus/RC/robotics-hobby DC solid-state drive/speed controller for the pump that could be run from an analog output off of a common microcontroller like the inexpensive PIC micros. One analog sensor to monitor pressure and you're in business... Hmmmm I smell a cheap product idea for an adjustable progressive controller...
Old Jul 23, 2005 | 11:44 PM
SOM_of_a_Beach's Avatar
I hope my question isnt too dorky as I am still learning.
I read on one of those sites that intercooled cars can't spray the mix before the intercooler cause it will condense in the intercooler. (My car is intercooled but typically runs at high temps.) So, does that mean I would inject after the intercooler or just spray the mix on to the intercooler and allow the heat to dissipate via evaporation?
quote from site: "What if my engine has an intercooler?: We do not suggest injecting water before the turbo in an intercooled application, as most of the water will condense out at the intercooler. However, our system works great as an auxillary sprayer to increase the efficiency of your intercooler. In this application, water (add ice if you wish) is sprayed on the exterior of the intercooler to carry away the heat. Simple, easy, and effective. Subaru WRX rally cars use the same type of sprayer on their intercooler (but I bet it cost more).
I would have emailed the dude from the site but, there was no email mentioned thru out the site.
Thanks,
Crystal
Old Jul 24, 2005 | 12:00 AM
anarchy99's Avatar
spray it after the maf but before the TB.
Old Oct 5, 2005 | 07:50 PM
Turbonoma's Avatar
And behind the iat sensor if you have one. PEACE>Tony
Old May 12, 2013 | 05:39 PM
JoshuaGrooms83's Avatar
i know old, but im wondering how an on/off set up boost pressure style switch would work? i tryed getting an AEM progressive controller to work, but i think it was defective and im tired of jacking around with it.
Im going to be using about max of 12psi on my setup. 10psi will be my normal setting, and 12psi will be my "track" days. however im thinking of having the water/methanoal kick in at about 6-8psi. would this hurt anything? im not using it as a fuel additive as i am for detonation prevention and cooler IAT's.
not sure how hard it would be to tune it like that and wether it has to be tuned with it?
any help with this would be awsome. again, this is just a temp until i get a snow performance later, but iwould like to at least use the AEM injection system. Everything is hooked up just the controller isnt working.
Old May 12, 2013 | 08:12 PM
Big_Shannon's Avatar
I am using a Hobbs switch. Napa has them P/N# 701-1575. Roughly 30 bucks
Old May 12, 2013 | 08:14 PM
so it has no problem just turning on/off vs progressive like the big name controllers? this doenst cause drivabiliy or tuning issues does it?
im only looking at 10-12psi at the most so im thinking of having it turn on at 6psi
