car died!
Old Jul 19, 2005 | 10:14 PM
HellRaiser's Avatar
I jumped it and still nothing. I do have the pumps rewire. I check the inline fuse and that was alright. I have to look more tomorrow.
Old Jul 19, 2005 | 10:19 PM
frcefed98's Avatar
Do the quik check I just pm'ed you about simple and easy to do to see if fuel is gettin to the rails.
J
Old Jul 19, 2005 | 10:28 PM
ddnspider's Avatar
take out the shrader valve in the fitting at the end and if fuel comes out Voila!
Old Jul 19, 2005 | 10:32 PM
frcefed98's Avatar
What if he has billet rails like me...hmmm??
Old Jul 20, 2005 | 12:34 AM
NA$TY-TA's Avatar
damn im going to sicribe to this one i want to know what happened also....
Good luck
Kyle
Old Jul 20, 2005 | 02:37 AM
99SS-T's Avatar
Lol. Ya had me scared with the title of this thread. I was thinkin man that has to be a ****** record. LOL. I definatly think it is a pump problem. Did you clean that tank out when you did the pumps. Maybe there is alot fo **** in the tnak and it got clogged. GL amn and keep us posted.
John
Old Jul 20, 2005 | 02:45 AM
NA$TY-TA's Avatar
John
99SS-T you ever get your car to the track yet after getting it tuned...??? A few people have these kits up and running and making power but no one has been to the track yet..... It will prob be Jer first LOL
Kyle
Old Jul 20, 2005 | 03:14 AM
99SS-T's Avatar
I have yet to go. I have a clutch that isnt happy ATM. I really wanna go so maybe ill go friday adn see waht happens. Only slips in 4th adn 5th so might be able to get away with it. It is definatly moving that is for sure.
John
Old Jul 20, 2005 | 04:30 AM
regorih383's Avatar
fire time
regorih383's Avatar
fire time1203
Old Jul 20, 2005 | 04:54 AM
HellRaiser's Avatar
I thought about setting it on fire.
Let me ask this. I put the fuel pump socks on even though I have a external filter. Was that bad Ideal?
I will work on it today after work..
First thing I will try is to remove the fuel line going into the FPR and see if fuel comes out when I crank it.
Old Jul 20, 2005 | 05:41 AM
  #32
Slowhawk's Avatar
LS1Tech Sponsor
Running an F-body out of fuel is BAD.Running dual pumps at a low fuel level is even worse!!!
You probly burn't up both pump's. I make sure all FI cars DO NOT go under 1/4 tank for this reason.
Old Jul 20, 2005 | 05:49 AM
  #33
2001WS6Vert's Avatar
If you have a canister filter you can put the guts in wrong and block off the fuel flow.
Old Jul 20, 2005 | 06:31 AM
  #34
NA$TY-TA's Avatar
Wise words to live by if you own a FI F-Body......
Old Jul 20, 2005 | 07:12 AM
  #35
Or maybe the hose a the pump blew off (since you hear the pump run). You could switch power to the other pump too.
Old Jul 20, 2005 | 11:32 AM
  #36
2000 Tran Zam's Avatar
you'd need to prove theres gas in the car in order to set it on fire first...
what if the fuel filter was fucked up? maybe clogged, could that cause an issue like this?
Old Jul 20, 2005 | 11:38 AM
  #37
hellbents10's Avatar
LS1Tech Sponsor
Definatly a possibility you blew a hose off one or both of the pumps in the tank. Seen it happen more then once with 340 installs. Anytime you mod that isolator keep the fuel level above half.
Old Jul 20, 2005 | 11:48 AM
  #38
ddnspider's Avatar
Thats what a Saws All is for
Old Jul 20, 2005 | 02:38 PM
  #39
HellRaiser's Avatar
Damn wish I knew that before. How can I check to see if they are burnt?
No chance on the fuel line blowing off. Its a -8 line with the fitting on it. I am thinking Slowhawk has got it. 2 pumps with about 1 mile on them. Is that a record of some sort?
Old Jul 20, 2005 | 03:54 PM
  #40
Dr.x's Avatar
hellraiser if you need help pulling the fuel tank I'm only up in reading I'd have no problem running down to give you a hand since you put gas in her?
