Need some help on a Cam for my STS KIT
I have a STS Turbo the basic kit 5 psi ... i am going to go with the interrcooled kit in a couple months....i was curious to kno what kind of cam i should get....i talked to comp cams and this is what they gave me.
SPEC CARD
PART #: 54-000-11 ENGINE: LS1 CHEVY LS1/GEN III '97-UP ROLLER
GRINDING INSTRUCTIONS 1
"" "" 2
"" "" 3
GRIND #: LS1 3713R /3713R HR114+2
SPC INST 1:
SPC INST 2:
J. DIAM: STD INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .564 .564
DURATION @ .006
TAPPET LIFT 273 273
VALVE TIMING OPEN CLOSE
@ .050 INT 0 40
EXH 48 8-
SPECS FOR CAM INST. @ 110.0 CENTERLINE
INT EXH
DURATION @ .050 220.00 220.00
LOBE LIFT .332 .332
LOBE SEPARATION 114.0
ROCKER ARM RATIO 1.70 1.70
or this one
226/220. I have seen a cam with the following specs make 635 @ 10psi. 226/230 .561 .566 on a 115 lsa.
im curious to know what I should go do
SPEC CARD
"" "" 2
"" "" 3
SPC INST 1:
SPC INST 2:
DURATION @ .006
TAPPET LIFT 273 273
@ .050 INT 0 40
EXH 48 8-
INT EXH
LOBE LIFT .332 .332
or this one
