Nitrous vs Alki for Turbo.
This time I will explain things as good as possible.
We are still in the street setup's. No race car's, not looking for 800 HP etc.
Lets say we are using a 346 longblock again with whatever Turbo setup you want. Its intercooled and makes 500 HP to the tire with 9psi.
Now we want a little more the cheep way.
We can turn boost up and run 11psi and Alki injection or we could spray it with a shot of nitrous.
93 octane is our limit on fuel but we will see a higher octane with the alki setup.
OUR goal is simple. What makes better power? What will produce better track results?
The nitrous is a 2nd power adder and cools great but from what I have seen you cant really up the boost any.
Uping the boost on the alki is the key as you see more octane, it cools very well and seems like it might be safer.
The Nitrous makes **** spool faster, does the alki?
-Bryan
John
the benefit of alki really is more timing. There was a comparison done where a member here added more timing with less boost versus more boost with less timing. Guess which one made more power? The one with more timing...
