Rear mount (STS) Dyno graph at 10 psi
Old Jul 20, 2005 | 08:20 PM
Zombie's Avatar
Default Rear mount (STS) Dyno graph at 10 psi
This car sucks, it has horrible lag and doesn't make jack **** for power. I wish I would have bought a front mount setup.
Dyno was on a manual boost controller, boost went to 11 then slowly dropped to 9 psi by 6000 rpms, hence the power drop. The bump at 3700 is where I picked up 2.5 degrees of KR. I was working on tuning the alcohol setup at the time. Mods in sig.
The car has a much improved tune from this now.
F' the haters, they don't have a clue.
Old Jul 20, 2005 | 08:32 PM
30th t/a's Avatar
yea that sts kit sucks!.......J/K..awesome numbers.
Old Jul 20, 2005 | 08:43 PM
Aaron's 00 TA's Avatar
Zombie, what FMIC are you using?
Old Jul 20, 2005 | 11:16 PM
verbs's Avatar
Serious question.....you have a cam, headers right? On paper your car should make say what, 350-360rwhp without the Turbo?
So you gained say 130-140rwhp with 10psi? Call me crazy but those gains seem a little low for a turbo setup.
Old Jul 21, 2005 | 12:01 AM
JZ'sTA's Avatar
I agree unless he is a A4 car. Then he might only make 340 on motor and be 10RWHP closer to normal results.
either way pretty nice numbers for a very cheep setup.
Old Jul 21, 2005 | 12:16 AM
Jammer's Avatar
Another shitty 500 hp sts system.
Old Jul 21, 2005 | 12:19 AM
boosted99camaro's Avatar
hey dont forget where he lives that makes a big difference.nice numbers
Old Jul 21, 2005 | 01:34 AM
marcus769's Avatar
I dont get the humor in this thread... zombie seems upset w/ 500rwhp with just that setup?? Sounds fine to me! I may have overlooked something!?
Old Jul 21, 2005 | 01:43 AM
Wildman's Avatar
He was being Sarcastic.
Old Jul 21, 2005 | 01:44 AM
JZ'sTA's Avatar
No he is making fun of all the STS bashers and being a smart ***.
Thats Vegas heat is nasty I was there last week.
**** those 115+ degree days.
Old Jul 21, 2005 | 02:09 AM
99SS-T's Avatar
What are the corrected numbers to REALLY shut the haters up? When i dynoed my car in the heat i was near on 100 hp below what it ran on a cool night. Im sure you woudl make a ton more in the cool. How much advance you runnin? GJ man
John
Old Jul 21, 2005 | 04:31 AM
LSs1Power's Avatar
Not bad, but i dont see whats the point of being sarcastic towards front mount turbo or Prochargers setups. It is still making less than Prochargers runing the same mods with 7-8psi.
Old Jul 21, 2005 | 04:52 AM
KraZy's Avatar
I'm not a STS basher but those numbers are low for 10psi.
Are they corrected?
:edit:
I noticed his cam - 112 - I wonder if that has anything to do with it
Old Jul 21, 2005 | 05:37 AM
Caveman's Avatar
10 & 11 Second Club
Seeing that Vegas is like 5000 DA + over 100*(probably 6500 DA), I dont think dynos can adjust for that extreme condition. In 80* closer to sea level that car would pick up 50-70 HP.
Old Jul 21, 2005 | 05:38 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I would like to see a power per dollar comparison on some of these different setups. Plus, I like the turbo torque curve a lot better than centrifugal blowers. It may or may not be as good at the track, but it's a lot more fun on the street.
Old Jul 21, 2005 | 06:47 AM
KraZy's Avatar
You cant argue his track runs though, awesome runs in LV
Old Jul 21, 2005 | 07:33 AM
PurEvl's Avatar
10 psi sts
Old Jul 21, 2005 | 07:50 AM
RealQuick's Avatar
Show me some procharger/vortech dynos where the make 490-500rwhp on 7-8psi and still have stock heads and stock bottom end...
By the way, you seem to not understand the sarcasm part...he is not sarcastic toward front mounts or S/C's, but to all the haters that say sts kits suck! Get it now??
Old Jul 21, 2005 | 07:57 AM
Got Me SOM's Avatar
shouldn't a fairer comparison be, show me some procharger/vortech dyno's that make 490-500hp at 9 psi with a 11 psi spike on stock heads and bottom end. *scratches head*
just wondering why you think the supercharger guys should make equivalent power with less boost.
Old Jul 21, 2005 | 08:03 AM
KraZy's Avatar
I know for a fact a Procharger at 10lbs will make more power than the graph he posted. All I can figure is the numbers are not corrected. PurEvl's graph is what I would expect from a turbo pushing 10lbs.
