Ordered the 3.7 pulley
Old Jul 21, 2005 | 08:13 PM
2000silverbullet's Avatar
Default Ordered the 3.7 pulley
I finally ordered the 3.7 from SDCE > and cant wait! Its pretty bad when you start checking the ups web site 2-3 times a day! I hope to make 10-13 psi and hopefully hit my 550 goal. Not looking to shred any records, I just want to haul some *** and 550 should get me there......maybe that ups driver needs a procharger > hurry up!!!!!
Old Jul 21, 2005 | 08:21 PM
618HAWK's Avatar
3.7 for 10-13#??? Its is going to be close I am running a 3.7 and ati superdampner 7-5/8 and only seeing a good 8 and low 9 #. But with a good tune you should be able to hit 550. I am at 540, on a 95deg day as well.
Old Jul 21, 2005 | 08:52 PM
I have a flowmaster (clog master) and stock ls1 intake > so I should see 10-13psi. I don't really care how much boost I make > I just want to hit 550 > the boost is just fluff talk if you know what I mean...
Old Jul 21, 2005 | 09:12 PM
NA$TY-TA's Avatar
Do you have the standard 8 rib from ATI or the SDCE kit....
Old Jul 21, 2005 | 09:39 PM
kp's Avatar
kp
his sig says 8 rib SDCE
I am seeing ~12psi @ 6600rpm with the 3.7 on a D1SC, it was 10psi with a 4" pulley and 14psi with the 3.4" through the hooker cat back just to give you an idea but I'm at 1500' and 90+ degree temps. A P1SC is usually 2-3psi less then a D1 for the same size pulley.
Old Jul 21, 2005 | 09:48 PM
HUGGER ORANGE SS's Avatar
618Hawk and I are at 8000 DA up here in Denver colorado.. You loose 20% to 23% power AKA Boost.. I'm running an D-1SC blower 8" Crank 3.4" Blower pulley and I'm seeing max of about 14 to 15psi of boost at 6500 engine rpms on a cool day. That's about 62,500 impeller rpms I'm spinning that D1 to..
Gotta love the air up here...
Clint
Old Jul 21, 2005 | 09:49 PM
He's running the ATI 8 Rib non spring tension setup...
Clint
Old Jul 21, 2005 | 09:56 PM
kp's Avatar
kp
Clint
oops, I didnt see Kyle was asking 618hawk what drive he had
Old Jul 22, 2005 | 05:46 PM
618HAWK's Avatar
Clint
Thanks Clint
Old Jul 24, 2005 | 06:38 AM
asnxps2's Avatar
Im using a 3.4 pulley and only seeing 8lbs of boost at 6600. Is this about right?
Old Jul 24, 2005 | 03:38 PM
NA$TY-TA's Avatar
Its alright Kev..... non of us are perfect..
Kyle
Old Jul 24, 2005 | 03:40 PM
NA$TY-TA's Avatar
Thats about right.... with a 408......i would see 10-11 wih my 370 and a 3.4" pulley... the bigger cubes is were its going........ you might have to step up to a bigger head unit if you are wanting to make alot more power.
Kyle
Old Jul 24, 2005 | 05:33 PM
Hey > just thought about this > will I be hitting the P1SC limit with a 3.7 pulley? I'm talking RPMS???? You math wizzes should be able to help me on this???
Old Jul 24, 2005 | 06:17 PM
kp's Avatar
kp
nowhere near it, 6500rpm is only 52K on the impeller - you have 10K+ more to go. Unless you plan on shifting at 8000rpm you are just fine
I would be more concerned with those 42lb injectors, they most likely wont get you past 550rwhp..
Old Jul 24, 2005 | 07:29 PM
NA$TY-TA's Avatar
Kev's right 52K rpms.... its easy to figure out man...
tahe the crank pulley size in "s
in your case 7.25 and divide it by the blower pulley 3.7" = 1.959 X that by the blower steup up ration of 4.10 = 1.959X4.10=8.03 then X that by your peak RPM so 8.03X6500rpm= 52,219 rpm
I sat buy the 3.4" pulley and s et of 60# injectors and another walbro 340 intank
Kyle
Old Jul 24, 2005 | 08:50 PM
From the looks of the way the 42lbers handled on the last tune I should be ok. The key is should be....
But you are right kp > they won't get me a whole lot more than 550. May be I'll make 551 and just be a luck guy.....
By Brett Foote | 2026-06-04 05:00:17
