What would you think max safe boost is?
I’m leaning towards 5 PSI, maybe another 1-2 PSI with methanol.
Mike
Mike
The Crank is only good for a reliable 550. Others are pushing beyond that, but I would not recommend it. As far as boost, 6psi would be the absolute upper limit with 11.1 compression. Dynamically that would put you somewhere around 18.1 or 19.1.
Dave
Don't recall seeing any instances where the stock cranks failed with stock hp, or even boosted? Are you refering to a spun bearing or what? That's usually the result of poor maintenance (CHANGE YOUR OIL!), over reving, or a poor rebuild.
I guess it depends on what your power goals are. If this guys not trying to change his compression ratio, he's probably going to be more concerned about detonation, lifting his heads or piston failure than stock crank failure.
Dave
There are people that are making over 550 on the stock crank. But As I said about my setup, 822RWHP on 93 octane, just because I can do it, doesnt make it reliable. For what a high performance engine cost. that should be a piece that is replaced. Harlan, from my understanding is using the stock crank making all of the power he makes, but my understanding he is not running it on a race track, he is taking it to drag strip, nice short little runs. I didnt say you couldnt do it, I am saying that it is not a reliable avenue to take.
I would imagine regardless of who I have pissed off in the past that anyone with any experience at all would agree, that anything over 550 on a blown application the crank should be replaced.
I am not sure of any aftermarket company out there, and in last months GM High Tech where every company listed their builds parts list, not one had the stock crank listed. If I am going to spend at least 10K on a motor, I can afford another 2K for a crank that will hold up. Guarenteed.
But I think effective CR of ~15:1 about max without engine grenading. That’s a little over 5 PSI of boost. I thought I would ask the question and see what forum members think.
As far as lifting heads – allot of other things will let loose before that happens on stock LS2.
Mike
Let's face it - you definitely make it a point to test the limits of your engine, therefore a forged crank is definitely the choice for you. However the guy that started this post is looking for 5-7psi, not 14-18psi!
I think for his setup, the stock crank will be just fine.As far as the stock crank goes in general, from what I have read so far, it seems like 550hp is reliable. It seems like people are making more than 550 reliable hp. If you're constantly testing the limits of your engine, than obviously a forged steel crank (or anything for that matter) is going to be better than the stock internals. What you need to decide is whether or not you can better spend that $1k-$2k somewhere else on your car. I think it all depends on what your goals are, but I would not sell your stock crank short at 550hp.
Keep to asking about a girdle.
thats my thoughts exactly Brian.
