I need a bigger turbo! Help me pick!
#42
Jose explain what the difference is between an OC and a tangential AR ratio.
#43
LS1TECH Sponsor
On-center flows about 4%-10% less air through the scroll then a Tang V housing. Typically to match the sizing of a Tang V, you need to work a 10% margin in on the A/R. On-centers are only good for turbo placement in comparison to a tangV. Also you backpressure is about ~3-5% more due to the tight turn the air has to make when initially entering the housing.
Jose
Jose
#50
Originally Posted by frcefed98
The GT42 is a tangential housing from what I read on Garretts website.
The GT series doesn't use the on center housing due to its lack of flow.
The Garrett comp housing is physically large compared to a standard T-series housing, 5 inch anti-surge versus standard 4 inch inlet.
Overall, the garrett pieces are just physically larger. But stuffing the 76 wheel into a normal comp housing and using a smaller non-garrett turbine housing lets the 76GTS be overall smaller dimensionally.
#56
LS1TECH Sponsor
Once the shipment arrives here they will be out the door. Including you guys. PTE has been slow and I appologize for the long wait times. We are working to get some units stocked on the shelf, but they keep selling faster then we can get them. I promise by the next few months I will try to have a bit of everything laying around for quick turn arounds. Its just right now its full blown in the middle of race season and people are breaking parts and upgrading to go faster.
#57
I have the T4 flanged GT42 and now I know its a 74mm too, thanks for the info Harlan and Jose.
J
#59
SSU'S Vice Mod
