Update on Turbo Project!
Old Aug 11, 2005 | 05:51 PM
  #61
2000 Tran Zam's Avatar
Originally Posted by SMDLS1
I am going to Futral tomorrow, Ive already heard it run, when Alan started it for the first time. I would record you car for you but I dont have a cam-corder all I have is a digital camera, and I dont know how to post pics.
So any pics or news at all? I spoke with candy today and she told me allan would be calling me today, but its almost 6 their time, so i dont think ill be gettin a call today.
im anxious to see what you have to think!
Old Aug 11, 2005 | 07:24 PM
  #62
fbodlovr's Avatar
Im not trying to steal your thread, but it seems like you and a few poeple in here know a few things about turbos. WHat turbo will make up to 1000hp???
Old Aug 11, 2005 | 07:50 PM
  #63
well are you talkin about 1000hp crank or rwhp. do you want it on race fuel or pump gas, how much money do you have to spend?
are you using a 346 motor or larger?
you could prob get away with it with a 76gts or gt42 if you wanted a little room to grow, but expect lag unless its a bigger CI motor.
i know jose knows his **** with turbos, so im sure he can chime in.
Old Aug 11, 2005 | 10:13 PM
  #64
V8_DSM_V8again's Avatar
Well I know of a 8 sec car with a Air to Air FMIC 1/3 as big as that...
I think Alan went a little Tim Allen when it came to FMIC sizing... He sure knows LS engines and F-bodies but all I do is turbo cars...
It will haul as but I would be seriously concerned about the radiators hampered capabilities.
Old Aug 11, 2005 | 10:19 PM
  #65
SMDLS1's Avatar
Sorry no pics but Alan was working on it today, and looks like he got a few more things done to it since i saw it 2 sat. ago. Just be patient, I know its gotta be killing you to, but Alan is not one to just throw stuff together, eveything that he was doing on your car and other cars at the shop were top notch.
Old Aug 12, 2005 | 12:58 AM
  #66
fbodlovr's Avatar
Yeah, I was thinking 1000crank. Is the 76gts huge like the gt42? Also, this would be on a 346 motor. Hope it doesnt take forever to spool. Would the phamspeed kit accomodate this turbo?
Old Aug 12, 2005 | 01:31 AM
  #67
NA$TY-TA's Avatar
I hope you have a bigger budget then most people do..... because BIG HP cars do not last very long..... asking that much HP from a car all the time is asking alot...... be prepared for rebuilds...... a 1000HP is easy to say.... but not easy to do......
Ive said my .02.......
Kyle
Old Aug 12, 2005 | 02:00 AM
  #68
Kyle
So you plan on rebuilding your motor shortly?
with my setup, i plan on having that motor hopefully as long as i own the car...
Old Aug 12, 2005 | 02:02 AM
  #69
the gts is smaller i believe. but the important things are going to be the a/r ratios and compression wheel sizes and things like that. one will help build pressure while the other allows for more flow(at least i think)
so it all depends on how the setup is...
Old Aug 12, 2005 | 05:38 AM
  #70
smokinHawk's Avatar
if your putting down 1000 at the crank you have to be prepared to go in there every so often and refresh your engine, depending on how hard you beat on it.
high HP cars are very high matenance, though still not as much as your typical female.
Old Aug 12, 2005 | 06:09 AM
  #71
NA$TY-TA's Avatar
Exactly...... i just didnt specify like Smokin....... If you do Boost alot and often do be prepared to buy new rings and bearings to keep that motor fresh...... we didnt say new block or rods or pistons....... Give Allen a call and he will tell you the same.... its just part of owning a Big HP car..... kinda like changing the oil.., but on a higher scale.......
Kyle
Old Aug 12, 2005 | 11:33 AM
  #72
Kyle
ya, that is understandable. I gues that would fall under maintenence...
still in the long run, its much cheaper then having a wife or gf.
on another note, i guess there was some miscommunication between my dad and candy.
looks to be another 2-4 weeks until it should be ready. Im gonna be patience and give him his space as he needs.
I just wish it was already a month down the road though.
Old Aug 12, 2005 | 11:36 AM
  #73
It depends on alot of factors. Shorter stroke boosted engines stave off ring problems like flutter alot longer. Offset wrist pins and selecting forged pistons that the MFG says can run a bit tighter helps too... A vacuum pump does wonders on top of all that.. Vee have ways of making boosted engines last. 1,000 hp being produced by 408 cubes is'nt that hard on the engine.. Yes more so than 600. I put over 600 to the ground using 2.0 liters.... That is thru 1/2 as many connecting rods...
1. Cooling system.
2. Oiling system upgrades & cooler+ post break in synthetic use
3. Vacuum pump.
4. Gradual idling Cool downs from hot always.
There are tricks but that much HP from those cubes using top notch parts will hold up better than the naysayers think....
