engine temp with FI
Old Aug 7, 2005 | 03:00 AM
bigbadblackws6's Avatar
Default engine temp with FI
what is everyones engine temp running at after its good and well warmed up?
what should it run at with a vortech?
what is considered to hot and should have someone look at it for me?
mine is running at about 195-200 or so but never higher then that
just wondering what is normal
thanks for the help
steve
Old Aug 7, 2005 | 05:42 AM
asnxps2's Avatar
I have a procharger and get those temps in 85-90 degree weather and I also cant run my AC because it starts to over heat.
Old Aug 7, 2005 | 06:14 AM
NA$TY-TA's Avatar
I never had A/C with any of my setups.... with my old Procharger setup it would be about 185-190 with both the Iron block and the stock motor... Stock thermostat and a tune for a 160 stat but never put one in... and the single fan that was supplied with the kit from ATI.... we will se with the new setup.... to me anything over 215 and i start to worry....
Kyle
Old Aug 7, 2005 | 11:11 AM
speedz06's Avatar
I run about 195 in traffic w/ac on but I had it to 220 yesterday because I was beating on it in 95 degree weather.And thats with a becool radiator.I also run a meziere elec water pump to take a little strain off the belt.Magcharged.
Old Aug 7, 2005 | 11:15 AM
HellRaiser's Avatar
I just did some logging and my temps were around 185 and thats beating on it to.
Whats everyone IAT get up to. I am seeing 85 while driving.
Old Aug 7, 2005 | 11:18 AM
speedz06's Avatar
one thing I do notice is that we all would like a cooler runner.I lowered temps alot with thr aftermarket rad.I couldnt run a/c in traffic in the summer with the stock radiator.I dont mean to ramble on but in defense of the stock radiator it was full of dirt,leaves etc and I could never get it as good as new.I think adding a good oil cooler would help.the vette has an oil temp guage the oil gets up to 250 sometimes.Engines are oil cooled also so this might help.
Old Aug 8, 2005 | 03:26 AM
ok cool then. i was just wondering if i should worry or not b/c its at like 170 in my other car and in this one it is almost 200 so i guess im fine. sweet
thanks
steve
Old Aug 8, 2005 | 08:54 AM
FastKat's Avatar
Yea good point... a good oil cooler will drop your engine coolant temps.
