STS METH INJECTION..once again need help on the install..
Old Aug 8, 2005 | 09:18 PM
frcefed98's Avatar
Default STS METH INJECTION..once again need help on the install..
Well I bought a new unused STS meth injection kit from armegeddon here on tech. Everything looks great but it has no instructions. The harness for this kit has 4 blade type connectors sticking out of the harness itself....WHY???
Where do you hook this thing up to, the harness is a monstrosity, but well put together.
Does the pump have to be below the tank?? I found the perfect place to mount the pump but it is above the tank.
How does the STS meth kit add meth? Does it add meth per PSI or does it just shoot meth once you are in boost? Doesn't seem like there is any adjustment on this.
Here is a pic of the harness, hopefully you well versed STS guys can help me out.
I've PM'ed quite a few STS peeps already, but no luck and armegedon looks to be out for the day
Old Aug 8, 2005 | 10:22 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
LOL! I can't help you out, but I love the picture Heres a bump for ya to help find someone who does know
Old Aug 8, 2005 | 10:25 PM
quicksilverado's Avatar
Try Billy at TRTturbo.
Old Aug 8, 2005 | 10:38 PM
SScam68's Avatar
ah **** Jer, what have you done now?
Old Aug 9, 2005 | 07:44 AM
frcefed98's Avatar
Frank I have no idea, it looks cool tho I was all gung ho to install it yesterday too
Will do quicksilver
Chad, thanks That was my exact thoughts on that damn harness.
Hopefully armegeddon will see this today and help a bro out
Old Aug 9, 2005 | 08:02 AM
RealQuick's Avatar
Most kits on the market are gravity fed pump setups. If this is the case with yours, then the pump needs to be lower than the tank. My pump has two quick connect male terminals on it, so thats where 2 of your "blade" connectors go (they are quick conect female connectors for reference). I assume the other two QC connectors go to a switch/alarm/LED??? Here is a pic where I mounted my setup (which is not an sts kit BTW)....
http://memimage.cardomain.net/member...58_77_full.jpg
http://memimage.cardomain.net/member...58_73_full.jpg
http://memimage.cardomain.net/member...58_64_full.jpg
Old Aug 9, 2005 | 08:05 AM
ty_ty13's Avatar
7 Second Club
red91z has a meth injection on his STS kit.... that car is nice
Old Aug 9, 2005 | 01:05 PM
red91z's Avatar
LS1TECH Sponsor
I'm pretty sure the fuse that came in the kit is a 15amp fuse. Really the easiest thing to do is lay the harness in the car. I thought the same thing about the wiring until I laid it in the car and then it all came together. I'll get my manual tonight and can explain the connections tomorrow if someone doesn't chime in before then. Sorry I couldn't be of more help today.
Old Aug 9, 2005 | 01:07 PM
RealQuick's Avatar
Jer,
did the kit come with a relay?
Old Aug 9, 2005 | 01:36 PM
ty_ty13's Avatar
7 Second Club
told ya he'd prolly chime in.....
jessie,
damn you! now your gonna make me spend all my money on a freakin turbo kit!
that was just soo damn funny riding in your car.... usually you get that gut feeling from a stand still.... but **** i got it at about 60
youll pay for it by me asking you a whole bunch of questions so get ready
Old Aug 9, 2005 | 02:15 PM
frcefed98's Avatar
Real quick, nope no relay, just a fused connection...which is odd isn't it. Nice placement....looks like the ol nose is coming off again on my bird
Ty and red91 thanks for the help...Race prep is going to be scanning me a copy of the instructions so that rocks.
Wiring stuff up is my weakness...so I'd like to play it safe then burn something up
Old Aug 9, 2005 | 02:21 PM
Armageddon's Avatar
...with cheese.
Hey buddy, sorry I'm out of town. Internet is few and far between. The fuse is a 15amp. I thought I sent one, I guess I had it set aside for some reason. Several of the blade terminals are to the pump itself. Notice if you look at the pump you'll see a couple male blades ground and power. Several go to it, if they are getting you some instructions that is awesome... I'm glad your sponser came through... I hope you enjoy your kit and I'm sorry for the inconvenience.
Old Aug 9, 2005 | 02:24 PM
Armageddon's Avatar
...with cheese.
Oh, and the pump is boost referenced like a boost referenced fuel regulator. When the harness senses the switch over from vacuum to boost it triggers the system.
Old Aug 9, 2005 | 02:27 PM
frcefed98's Avatar
Cool thanks buddy, I'll pull the pump out of the car and see what goes where..I didn't even look at the pump much just mounted it up
I've got the blade fuses in the tool box, so that isn't a problem
J
Old Aug 9, 2005 | 08:49 PM
frcefed98's Avatar
Thanks Bryan at Race Prep!!! Bryan sent me the manual today!!
Now I have something to do tomorrow
J
