incon intercoolers question flow/efficiency
Also thinking about a bigger pump to spray more alky. i read on the turbo buick sites that the alky really drops their egts. If that is true, wouldnt that help the lack of exhaust flow out of the incons? I am not changing kits...just trying to maximize the incons. I understand exhaust heat helps spool but I imagine my backpressure is already too high so maybe cooler egts might help that a tick.
For those who think the idea is nuts, turbomustangs.com has several cars making more power than me with no intercooler so it can be done.
after that the only real way to tell is probably experimenting.
my car has the razor progressive kit and if the control is turned up for too much alky it misfires so bad as to give kr.
why aren't you running straight meth?
I still think i can do that now with stock intercoolers and alky in cooler weather.
Most of the front mounts (not all) are horizontal flow...which could be less efficient in terms of pressure drop than the Incon's.
Harlan probably already knows the answers to my guesses.
I go from 100-110 after a burnout to 145-150 or so in hot weather.I have been considering dumping the IC and trying water/meth instead. Save 40lbs off the front
my TTi intercooler got me some 190-200 in 90* weather.
does the 4" OBX weigh that much? I ended up ordering one as my A2W wont fit where i want it to and dont have the time or money right now to do another, and if its good enough for you to get nines, it will be good enough for me for a while.
i think im going to cut one of the end caps so one is on the top and one on the bottom then reweld it. i think that will help some with cooling, maybe after i switch to the megasquirt and ditch the MAF, ill convert it to a 4" outlet too.
No doubt flipping one tank over will help some, I still have the battery in the stock location and I couldnt find a good way to make that work without redoing all the piping.
I would say the IC is at least 25lbs (maybe more, I weighed it but forgot what it weighed), plus the brackets, plus the extra piping would get me 40lbs off the front, less whatever the meth kit would be.
Shame its not easy to do a FMIC on yours cablebandit..
Biggest difference for me is leaning the car out when its hot, just dont forget to richen it back up when it gets cooler
I usually just adjust the fuel pressure at the track, when it ran 9.90 I had it at 61psi to keep a 12.5 a/f, I ran 57spsi to keep a little above 12:1 last saturday. If you are running on just the PE table the fueling will vary quite a bit by temp, wont make a huge difference if its 'close' but if you are looking for those last tenths it does. do you have any room to do a bigger ICs? if your willing.
another option is to spray no2 or co2 on the ic, or just a small shot in the system.
I need to do the tests for temp/pressure and then make a move.
