boost gauge placement?
Old Aug 10, 2005 | 07:31 PM
30th t/a's Avatar
Default boost gauge placement?
im getting my boost gauge, LC-1 and fuel pressure gauge and i want o know wheres the best place to mount that can been seen the easiest? on the a pillat or in the 3 heater vents above the radio? what do you guys prefer?
also for the boost and fuel pressure should i get mechanical or electrical
thanks for the help
John
Old Aug 10, 2005 | 07:32 PM
ddnspider's Avatar
electrical and in the vents to be cleanest.
Old Aug 10, 2005 | 08:01 PM
anarchy99's Avatar
Default Gauge placement..
I've got a great picture of my dynotune boost gauge mounted... only problem is I can't get the picture saved small enough in order to get it mounted. If anyone knows how to get it to 100kb, let me know or I'll send it to you via email and you can post it. Also got my boost controller in the picture.
Old Aug 10, 2005 | 08:10 PM
anarchy99's Avatar
Default maybe this will work...
It's on the 2nd page of this website... hope it helps.
http://www.wtfba.org/forums/index.php?topic=9724.20
Old Aug 10, 2005 | 08:29 PM
NA$TY-TA's Avatar
2 1/16 gauges dont fit in the A/C vents so i hope you bought 2 5/8 gauges..... I have my Boost in the A/C vent and my Elec. Fuel Pressure gauge in the A-Pillar..... my Elec Boost controller will be in the other A/C vent down the road....... Put the LC-1 in the bottom pillar mount and the elec Fuel Pressure gauge in the top one.... FYI an Elec gauge is the ONLY way you can legely runa fuel pressure gauge in the cab......
Kyle
Old Aug 10, 2005 | 08:35 PM
DarkFormula's Avatar
I have my boost, A/F, and fuel pressure mounted in the A-pillar using a triple gauge pod for 2 1/16" gauges. I have 2 5/8" tranny temp and oil temp gauges in my far left A/C and center/left A/C holes.
www.unleadedanalog.net/pics/gauges1.jpg
www.unleadedanalog.net/pics/gauges2.jpg
Old Aug 11, 2005 | 12:08 AM
LoWeLL216's Avatar
I mounted mine in the gauge pillar. It's easy to see and is a clean easy install. If you're after the sleeper look obviously you'll want it somewhere else though. Electrical gauges are easier to install since you're just running a few wires instead of lines, but they're more expensive.
thanks for the help
John
Old Aug 11, 2005 | 12:43 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Is there anything wrong with a mechanical vacuum/ boost gauge?
Old Aug 11, 2005 | 01:45 AM
LoWeLL216's Avatar
Absolutely not
Old Aug 11, 2005 | 04:50 AM
HellRaiser's Avatar
Old Aug 11, 2005 | 06:33 AM
NA$TY-TA's Avatar
Showoff... so ill show mine....
Ill have an eBoost beside it sooner or later...
Kyle
