7000 to spend
Old Aug 12, 2005 | 12:23 AM
JZ'sTA's Avatar
Sure do.
With the time and energy it took you to get your setup right and making power I wouldn't beable to buy that kit from you for a million dollars.
Old Aug 12, 2005 | 12:36 AM
JZ'sTA's Avatar
Originally Posted by goober35
http://www.forcedinductions.com/GMkits3.htm
One of the kits i am looking at. Looks like something u might want to look at also.
This kit looks real nice.
I dont like the 700 dollar for the bigger turbo but no big deal there.
3599 for everything but the intercooler and turbo sounds nice. Its only 600 dollars to add a T70 but 1400 for the T76. That is kinda high. Also 1200 bucks for a intercooler Thats just not gonna happen.
Could spend 3600 on the kit plus maybe 1700 for a nice turbo and intercooler and you have one hell of a setup for 5300 bucks.
Old Aug 12, 2005 | 08:52 AM
RealQuick's Avatar
5399 for a small T70 with air to air or upgrade to the T76 for a total of `$6200. There goes most of your 7k budget and you still need injectors, fuel pump?, tuning, etc.
Old Aug 12, 2005 | 06:39 PM
Got Me SOM's Avatar
Turbos and intercoolers aren't cheap by any means. Make sure you don't go too big or it will be a laggy s.o.b, don't just go for peak horsepower.
If you do the install yourself you should have enough in your budget to get a good system, he already said he has the fuel so he should be ok.
Old Aug 12, 2005 | 07:10 PM
longrange4u's Avatar
Are you talking just the turbo? What about Suspension, Rearend, Clutch/Converter, Fuel system / injectors... etc etc..
I think you could do it pretty cheap with a STS, FMIC, and a T-67 instead of the T-60. (Keep in mind even cheap... I am not sure you can stay under 7K)
But I am still kinda a noob... what do you guys think?
Old Aug 12, 2005 | 08:41 PM
ddnspider's Avatar
with no forging,and either stock or a good price on heads and cam you could do it for $7k
Old Aug 12, 2005 | 09:45 PM
And just FYI... for me instead of buying a T-67 I have a Trimmed and Pollished t-60... If I ever need more I can have a 67 wheel installed... much cheaper then buying another turbo.
