Why is this happening? Re: Boost Falling Off
Might even try to just take it out for one easy run and see if that cures your problem. If you build boost then, well you can either narrow it down to a bad BOV or a Vacume source problem.
SDCE is your friend
SDCE+ATI = perfect set up.
EDIT..now thats more like it, with the SDCE set up you won't have to worry about the belt ever again.
MMS was fun but I ran through belts like nothing with that set up...the cog was even worse.
I really wish ATI would actually try to make a kit that works, especially when someone lays down that much $ for one. Without any outside modifications mine couldn't even hit 5#........... pathetic.
