Blown Head Gasket
Matthew
https://ls1tech.com/forums/forced-induction/344982-best-forged-piston-forced-induction.html
If you have the cash I would replace the rods at the same time, and if you realy want to spend the cash go for a set of low compresion heads sence they are off any way. Which should take full use of that GT2-3, along with turning up the boost a bit, and you should meet your 600-650 DD goal, with no problem.
Oh ya you said you have 97 heads, not sure how they would be to a set of AFR 205, 225,s. My next choice
https://ls1tech.com/forums/showthread.php?t=344982
Chris is there a problem with your motor??
Clint
So what about connecting rods? Is there something I should be looking for, or should I just buy the least expensive forged connecting rods I can find?
Thanks for the help.
Other than that sounds like you are on your wat to doing it all right. I would have got the diamond rings when you ordered your pistons. You are going to have to set your ring gap. Find out how much power you want to run in the future and do some math to fugure out your ring gaps or you can just do what everyone else does and copy someone elses setup.
you can get a Tnt ring which is pretty much the same as helfire, but is avalable in the 3.905 bore.
