Phamspeed Dyno #'s
Old Aug 14, 2005 | 09:16 PM
  #61
HellRaiser's Avatar
hellraiser how bad was the hookup and figuring out the Eboost?im wondering how bad its gonna be to do the Eboost2 i have
Hook up is easy its getting it dialed in that sucks. I might just sell it and go with a manual setup
Old Aug 14, 2005 | 09:18 PM
  #62
HellRaiser's Avatar
Originally Posted by frcefed98
Like I said up top, simple manual boost controller for me....all those features on eboost just put me off even more
I agree, you are tuned safe(and tuned) Save up some more cash and get another tune and the correct boost settings and let it run
I'm just running off WG for now, until I get my fuel issue solved with new lines.
Hope to give you some company real soon numbers wise Pat.
J
you should make some big numbers, I wanna see you break into the 10's
Old Aug 14, 2005 | 09:19 PM
  #63
ddnspider's Avatar
geez that bad??? i bet its worth it when you get it dialed in though....plus it looks
Old Aug 14, 2005 | 09:20 PM
  #64
ddnspider's Avatar
now correct me if im wrong but if you have a 6psi spring in the wastegate and you want to run say 10psi at the track then wouldnt that open the wastegate early and create lag???
Old Aug 14, 2005 | 09:23 PM
  #65
frcefed98's Avatar
10.99 and i'm done its all I ever wanted for this car...first goal was to beat vipers...powerdyne did that for me, then it was 11.99's ATI did that for me, now its 10.99 and I'm done...wallet can't handle it anymore and I think my family is getting tired of it...my pops said it yesterday "this turbo set up is getting to be real expensive"
I'm hoping for 600rwhp
J
Old Aug 14, 2005 | 09:25 PM
  #66
frcefed98's Avatar
You are wrong....you've been corrected.
The wastegate won't open until you hit ~10psi and it will keep your boost at or near 10psi all the way down the track....if you have your eboost set up correctly.
J
  #67
EightBall's Avatar
J
Im with you here. 10's and I stop.
Old Aug 14, 2005 | 09:27 PM
  #68
EightBall's Avatar
running off just the wastegate works fine and all, but I noticed GREATLY increased spooling when I added my little homemade MBC. I wont go back to straight WG operation.
Old Aug 14, 2005 | 09:28 PM
  #69
frcefed98's Avatar
yeah I'm still on the stock tranny and 10 bolt...anymore and I run the chance of really having to replace them Too much money for me at the moment to replace both of those
Just one damn pass in the 10's, JUST ONE!!!!!
J
Old Aug 14, 2005 | 09:30 PM
  #70
CHRISPY's Avatar
Nice numbers but...
Get a manual boost controller.
I know of a couple of people who have had major problems with that damn e-boost.
Good luck
Chris
  #71
EightBall's Avatar
J
Once I get 10's, Im ditchin the turbo and the kit as a whole, maybe someone on here can use it. My next direction for the car will be for road track racing.
And...oops, nice hijack eh?
Sorry!
Old Aug 14, 2005 | 09:34 PM
  #72
frcefed98's Avatar
Arrgghh We hijacked another one Arrghh....sorry pat
Old Aug 14, 2005 | 10:02 PM
  #73
RICE ETR's Avatar
Turbo Addict
Nice numbers... but you have got to get that e-boost set-up right.. contact MIGHTYMOUSE... i know his works wonders now. you can make the car spool up quicker than with a mbc with it as well... he once had his overboost cutting the boost in half like yours is now.
Old Aug 15, 2005 | 12:32 AM
  #74
99SS-T's Avatar
Those are some nice numbers man. My setup is at a VERY conservative 13* at peak TQ and 10* at redline. I hope to get alot more TQ when i re tune. If you have a chance find out what the timing is set at in ya car. it is nearly as important a # as boost. GL
John
Old Aug 15, 2005 | 10:34 AM
  #75
ddnspider's Avatar
J
then what does the spring in the wastegate do as far as what psi its rated to?
Old Aug 15, 2005 | 11:22 AM
  #76
EightBall's Avatar
The pressure rating applied to wastegate springs is related to when the gate will open and stop boost from building.
For example, I have a spring that keeps boost from going over 7 psi, but that also means that I can't run any LESS than 7 psi, even with a boost controller. The boost reference going to the wastegate connects to a chamber inside the top of the WG which holds a diaphragm and a spring. The pressure exerts force on the diaphragm, and the spring keeps the valve closed until enough force is exerted on the diapragm, in my case it's 7 psi.
Hope that helped.
Old Aug 15, 2005 | 04:30 PM
  #77
HellRaiser's Avatar
OK guys I think Imight of figured out the lag problem. Tell me what you think.
The eboost has a function called gate pressure. Its something that you can set to tell the wastegate when to open kind of. You wanna make it stay shut for as long possible without going over youre boost setting. It makes spool up quicker and stuff. I had mine set to 3psi so do you think once I hit 3psi the wastegate started to bleed alittle boost therefore creating lag, making the turbo work hard as hell to get to 10psi(to only hit my overboost setting ).
Let me know what you think.
Old Aug 15, 2005 | 04:53 PM
  #78
Zombie's Avatar
John
Who tuned that?? 13 at tq peak is probably ok, but 10 on the top... WTF?
It should be morel like 13 for 500 before and after tq peak and then ramp up 1 degree very 500 rpms or so.
My table does 11 at tq peak and up to 18 by 6500. Thats all our craptacular 91 octane will let me get away with and be safe in 110+ weather.
Old Aug 15, 2005 | 05:32 PM
  #79
frcefed98's Avatar
But you are running meth right? I can understand his timing being low if he isn't running meth or race gas on the street.
Pat, Pm'ed you buddy...damn that eboost is confusing
Old Aug 15, 2005 | 05:33 PM
  #80
HellRaiser's Avatar
K just got a pm back from Mightymouse( he knows the eboost) and he said that the low gate pressure setting would slow my spool up. I feel stupid as hell. All that time on there and I never set the eboost up. I was just worried about blowing my motor up.
