Big boost guys inside please!
Old Aug 14, 2005 | 04:43 PM
Wet 1's Avatar
Default Big boost guys inside please!
Most seem to think 15 psi is about as high as you can go and not have to worry about the heads lifting. I've heard of many people running with more than 17 psi (some a lot more) and I'm wondering what the proven method is now to keep the heads down with this crappy 4 bolt per cylinder design. I suspect poor fuel systems in the past have led to detonation which lifted the heads, but I think this has been mostly adderssed. With that said, what are you doing to keep it a glued together?
What head gaskets are you using?
HG thickness?
Which head studs?
What size studs are you using, does going to 1/2" help much?
What compression ratio?
What block?
Which heads?
Have your heads/block been O-ringed?
Any other tips?
I'm going to be building another engine soon and want to make sure I have it setup correctly for big boost. If you're uncomfortable posting your secrets, a PM would be VERY much appreciated!
Thanks!
Old Aug 14, 2005 | 04:59 PM
Armageddon's Avatar
...with cheese.
Flatout Copper Gasket
40 thick
ARP Studs
Stock size, havn't needed 1/2 yet
8.8:1
Iron
Patriot LS6
Stainless O-Ring in block, no receiver grooves in head
Put silicone around the water jackets if your going to use copper gaskets or you'll leak coolant
Old Aug 14, 2005 | 05:07 PM
Reject's Avatar
Armegeddon, what do you run at the 1/4? is your setup pretty streetable?
MIGHTYMOUSE's Avatar
6.0 stock mls gasket
thick all pro heads
stock replacement arp studs, 80#
iron block
~8:1
24psi at times (oops)
Old Aug 14, 2005 | 05:12 PM
Wet 1's Avatar
Good info guys (thanks), please keep it coming!
One other obvious thing, please list how much boost you're running.
Thanks again.
Old Aug 14, 2005 | 06:30 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
6.0 heads
A1? head studs
aluminum block
~8:1
18-21 psi
Old Aug 14, 2005 | 11:34 PM
Zombie's Avatar
Stock everything, seen 16psi many times, 13 psi a whole lot and 10 psi every day.
I'm on a T76 now, 13-14 psi.
The amount of boost you run has nothing to do with lifting the heads, it's the amount of power you make and how much you detonate.
Old Aug 17, 2005 | 11:14 AM
Wet 1's Avatar
ttt...
