BOV open at idle
Old Aug 22, 2005 | 08:25 PM
HellRaiser's Avatar
Default BOV open at idle
I have the tial 50mm BOV and I noticed today while I had the hood open that the valve was open at idle. I gave it a little throttle and it would close but when you let off the throttle it would pop wide open and then settle but still stay open. Is this normal?
Old Aug 22, 2005 | 08:29 PM
Brent@LPE's Avatar
yes BOV works off of manifold vacum, when throttle blades are closed vacum is present valve opens this is how it works....
cheers....
Old Aug 22, 2005 | 08:30 PM
HellRaiser's Avatar
Good I thought it was just kinda strange.
Old Aug 22, 2005 | 09:00 PM
Louis's Avatar
Depends on the setup really. Some twin setups must be open to prevent slosh or surge. Part throttle stuff most require them to be open.
Old Aug 22, 2005 | 11:11 PM
y2khawk's Avatar
hmm
I had to cut the springs down to make mine open at idle. But my cam made very little vac. What's your idle vacuum?
As long as it's before the MAF, it don't matter. If you're SD, it really don't matter
Old Aug 23, 2005 | 04:49 AM
HellRaiser's Avatar
The BOV is berfore the MAf and the car makes around -20 vacuum.
Old Aug 23, 2005 | 03:54 PM
frcefed98's Avatar
well I guess I have to cut my spring down some more..mine is shut at idle..
I have a pretty large cam and its killing VAC so I guess i'll be chopping it in a few
J
Old Aug 23, 2005 | 04:53 PM
will62085's Avatar
my turbosmart instruction manual says it should be shut at idle, heres the quote directly from it;
"- Adjustment to the BOV III PB is made by rotating the cap (see figure 1), to increase spring tension rotate in the direction of hard, marked on the top of the cap
- Rotate the cap in the direction of soft to decrease the spring tension – CAUTION Do not rotate the cap beyond the indicator groove (see figure 1)
- With the engine at idle the exhaust port should be closed off by the piston – the piston should be hard against the seat and not floating or moving
- Free rev the engine and back off quickly, the engine should return to normal idle speed – if the engine drops below idle or stalls increase the spring tension by half a turn
- Repeat this process until the engine free revs and returns to normal idle speed"
i know your using tial but they all operate the same...
Old Aug 23, 2005 | 05:02 PM
frcefed98's Avatar
Well good? Got two conflicting things now Maybe I'll just leave it alone....but it would be cool to have it bypassing at idle and cruise...hmmm....
I really trust what harlan sezs too so
Old Aug 23, 2005 | 05:49 PM
HellRaiser's Avatar
Yeah I am with ya on that. His car does wheelies..........
Old Aug 23, 2005 | 09:40 PM
frcefed98's Avatar
And he's been doing the turbo thing with stenod and his ride for a lot longer and with more success than a lot of people here so i'll stick to what harlan sez....and he does wheelies...but so does my car
Old Aug 24, 2005 | 12:19 AM
2000 Tran Zam's Avatar
i gotta huffy that will put your cars to shame
Old Aug 24, 2005 | 02:58 AM
METAL MAN's Avatar
Open is fine for a MAF car, that is long as it's before and not after the MAF.
