Undecided on gauges
Old Aug 24, 2005 | 12:50 PM
rookie501's Avatar
Default Undecided on gauges
I am winding down on the procharger install. I can't decide which gauges to get. I know I want boost and fuel pressure. I am unsure of what the 3rd one should be. I was thinking oil pressure or oil temp. Any thoughts?
Old Aug 24, 2005 | 01:48 PM
mdhmi's Avatar
Why are two not enough? Do you really think that you can look at three independent gauges while you are running at WOT ?
Mark
Old Aug 24, 2005 | 02:13 PM
1bad2k2ta's Avatar
Mark
mdhmi has a valid point, but check this one out.
http://www.aeroforcetech.com/index.html
I will probably get one of these, but I am holding out for a chrome bezel which they don't currently have.
Old Aug 24, 2005 | 02:28 PM
Ferocity02's Avatar
Since you have a 2000, your stock temp gauge is a useless piece of trash. So I would reccomend getting a water temp gauge for your third one. Some people have overheating problems with forced induction so watching your water temp is a great idea.
Old Aug 24, 2005 | 02:44 PM
rookie501's Avatar
It's a sense of security. It's nice being able to see what going on under the hood. Yeah I may not be able to see them all at once, but I may see them one at a time.
Old Aug 24, 2005 | 05:51 PM
disassembled's Avatar
I would think you would definitely need a Wide band O2 gauge. If you lean out you will be able to see it right away and hopefully shut it down before anything gets hurt. I am giong with the LC-1 and their wideband gauge. Good luck. Oh, BTW, you can purchase all of the items you are looking for through dynotune.com which is a sponsor.
Greg
Old Aug 24, 2005 | 05:57 PM
ddnspider's Avatar
i just bought 1,should be here friday....i wanted a stock looking piece so no chrome for me. and ps....if you set the Interceptor to read knock you dont need a wideband because youll know if your starting to detonate.
Old Aug 24, 2005 | 07:02 PM
69firebird's Avatar
DD have you gotten it in yet? It looks to be a nice unit, does it have a plug that just goes into the OBDII port???
Man that is very interesting I need to get one of those.
Will Save me on alot of guages cluttering up the interior
just boost, fuel pres, and wideband
Old Aug 24, 2005 | 07:08 PM
ddnspider's Avatar
my tracking said it should be here fri/sat.....im planning on posting in the FI section about it once i get it.....obviously ill be on the motor in the car now not the beast thats being built but it should still be informative....ive already talked to Zombie about it as hes where i got the info from....basically im going to put it in the center ac vent snake the wiring down through there and plug it straight into the obd2 port....and run power/ground.Done....basically ill be using the Interceptor,Eboost2,and prolli a cheap fuel pressure gauge since ill already know if im going lean with this by showing knock and injector pulse.for those that didnt see it itll post any 2 of the following:
RPM
MPH
Intake Air Temperature
Mass Air Flow Sensor Frequency
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
injector Pulse Width (bank 1 and 2 if supported)
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Transmission Temperature
Idle air Control Counts
Throttle Position Percentage
Throttle Position Voltage
Engine Load
Oil pressure (some 8 cylinder engines)
and can record a short ~40sec interval of any of these.
Old Aug 24, 2005 | 07:30 PM
69firebird's Avatar
isnt it a 2 1/16 guage?/
I thought it was the 2 5/8ths guage that fit in the ac vents.
either way i have to get one
Old Aug 24, 2005 | 07:47 PM
2000 Tran Zam's Avatar
if you have a triple pod gauge, and dont have a boost controller already, ditch your current boost gauge and get the eboost 2, its a boost controller and boost guage in 1...
if your auto, maybe you can get a tranny temp gauge(assuming your not since your sig says spec 3 clutch).
um, other then that id prob say an oil pressure gauge.
Old Aug 24, 2005 | 07:52 PM
ddnspider's Avatar
ed.....https://ls1tech.com/forums/showthrea...=ac+vent+gauge
tranZam...if you get the Interceptor 1 of the things itll monitor is Transmission Temperature
Old Aug 24, 2005 | 08:07 PM
618HAWK's Avatar
Fuel Press, Vac-boost, and a good Wide Band for the added security, and you be set and safe.
Old Aug 24, 2005 | 08:32 PM
69firebird's Avatar
DD,
I didnt think of that, its just easier to get the 2 5/8, ill put this one in the guage pod.
and I still wouldnt think of this as a replacment for a wide band
Old Aug 24, 2005 | 08:34 PM
MTBDOC's Avatar
Boost and AFR. I just finished my install of the Wideband Commander. Has some great logging capability, AND it uses a Autometer Phantom gauge, so you can match a boost gauge.
I also eagerly await the CAN-compliant interceptors...just not sure where to put a lot of extra gauges!
Old Aug 24, 2005 | 08:35 PM
69firebird's Avatar
water temp is always a good one, since the factory one only reads too hot just right and too cold.
perect if your goldielox
Old Aug 24, 2005 | 08:39 PM
ddnspider's Avatar
i dont see how it couldnt be a replacement for the wideband.....if ur running lean your going to knock.....the interceptor will pick up knock B4 its audible as well as injector and fuel trims,whereas a wideband will only tell u ur going lean.
Old Aug 24, 2005 | 08:54 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I really wanted these gauges, but I'll have to hold off on them until the price comes out of the stratosphere first...
http://www.egauges.com/vdo_grou.asp?Series=Nexus&Cart
How much is that Interceptor Scan Gauge? That looks pretty cool. (I'd assume you can't see boost on it since our cars weren't FI from the factory tho?)
Old Aug 24, 2005 | 09:02 PM
ddnspider's Avatar
got mine for $230 shipped i believe
Old Aug 24, 2005 | 09:07 PM
ChevyChad's Avatar
And that includes the wire that goes into the obd2 port right?
*edit: nevermind, I figured out how to navigate their website for myself
