STS IAT location?
Old Aug 24, 2005 | 08:31 PM
Public's Avatar
Default STS IAT location?
Where is the IAT location on an Fbody LS1 with an STS kit?
Anybody have a pic? I just dont see a spot for it and the instructions I have are LT1 and done on a black-n-white copy machine so NONE of the pics are visible.
Looks to me as if they just tie it up somewhere and dont use it?
Old Aug 24, 2005 | 09:41 PM
Sonicmix's Avatar
I'm gonna try to say this right...On my LS1 it's located on the charge pipe right after the silicone elbow connected to the throttlebody. And since a picture is worth a thousand words I've attached one
Hope this helps.
Old Aug 24, 2005 | 09:43 PM
Public's Avatar
Well I'll be a S.O.B.! I dont have the hole in that pipe. It's where I would have expected it to be though. Is it the standard LS1 IAT that pushes in or a threaded unit? Thanks for the pic and info.
Old Aug 24, 2005 | 10:22 PM
Sonicmix's Avatar
Ok, I had my STS kit installed so I'm not sure how it came from STS.
But it sure looks as if STS included either a grommet for the IAT sensor to fit into, or the pipe may have come with the sensor installed. I dunno, maybe someone who has done the install themselves can chime in.
Here's a closer picture of the sensor install location, not the best angle but hopefully it will be of benefit.
Old Aug 24, 2005 | 11:54 PM
Public's Avatar
Well my IAT is now in the same pipe and spot as yours. I drilled a slightly smaller hole into the pipe than what was in the airbox. That accounts for not being flat then used a bit of sealant and popped that sucker in. I'm letting it setup overnight before reinstalling it. It was a "FIT" but not tight enough to cut the grommet, problem solved. THX again!
