Its finally here
Old Aug 24, 2005 | 11:17 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Talking Its finally here
The adventure has begun!
(Its for the T/A)
Thanks Dan (LS1 PLUS)
Old Aug 24, 2005 | 11:18 PM
yellow04's Avatar
Sweet let the modding commence!!!!!
Old Aug 24, 2005 | 11:19 PM
solobaric's Avatar
Good Luck!!
Old Aug 24, 2005 | 11:23 PM
bootleg<detroit>'s Avatar
DAMN!!!!!!!!! God that TA is bout the sweetest lookin car I seen,man,your lucky.
Old Aug 24, 2005 | 11:29 PM
bob19's Avatar
Just Got Done With Mine Today Had A Few Bumps In The Road Though Good Luck
Old Aug 25, 2005 | 12:48 AM
Public's Avatar
I'm looking for an ATI twin intercooler setup for Fbody if your going FMIC.
Old Aug 25, 2005 | 01:02 AM
HUGGER ORANGE SS's Avatar
Welcome to the Club... A Few things...
Broken Arrow gets hot durring the summer, I know... That Single fan will not keep up with the cooling for the motor.. You will overheat.. Trust me on this..
1st off I would not run that Black Shroud attached to the Single Fan.. It hinders airflow while the car is moving.. Take the Fan off the Black Shroud and attach the fan directly to the radiator itself on the passenger side of the radiator, using the plastic ties that you can buy at a autoparts store that mounts electric fans to the radiator.. Go out and buy a 10" to 12" Pusher fan for the oppisite side of the Radiator/Condenser on the driver side of the car, and have it push air as the larger fan you got from ATI pulls air. This will Keep your Temps at bay with the summer heat. And you won;t need to touch it int he future.. Trust me, you need to do this..
2nd... If you plan on running 8psi or more I would not route the ATI surge valve back into the inlet pipe because it recirculates HOT air.. I would blow it off to the atmosphere..
Other than that Get a good tune and follow the instructions ATI gives you..
Good Luck!!
Clint
Old Aug 25, 2005 | 08:03 AM
ChevyChad's Avatar
Thanks guys. And thank you for the advice Clint. I do plan on getting an additional fan for sure! I will be starting out at 7# of boost. I may just dump the valve to the outside anyways tho.
Public- PM me. Maybe we can work something out with the intercoolers...
Old Aug 25, 2005 | 11:54 AM
Good Idea... Please Do Ditch the Black Shroud the fan is on right now.. I had a overheating problem Running that single fan and the black shroud with stock motor and 6psi of boost...
Clint
Old Aug 25, 2005 | 12:13 PM
Malicious's Avatar
Kick *** Chad, good luck with it
Old Aug 26, 2005 | 11:31 AM
stryker14's Avatar
Looks like way too much fun. You know you are gonna have to give me a ride when its all installed dont you
Old Aug 26, 2005 | 12:22 PM
ChevyChad's Avatar
You bet man
Old Aug 26, 2005 | 01:23 PM
Malicious's Avatar
Me too Chad, if I ever get back to Tulsa anytime soon
--Travis
Old Aug 26, 2005 | 02:40 PM
ChevyChad's Avatar
