turbo-cats issues
Old Aug 29, 2005 | 11:27 AM
Turbo LS1 SS's Avatar
Default turbo-cats issues
i have the sts kit.
took off stock cats, put on cat bypass pipes. cars LOUD. noticable performance pick-up. sounds sick at idle, but very droony/shitty at half throttle. unbearable.
obviously cats on turbo cars are a no-no, but i can't keep these bypass pipes on, the cops will be on my ***, and it sounds like shitola.
my question is, whats the best, low-price, highest flowing cat that WON'T come apart and f*** up my turbo?
or is there any other way to fix my problem.
stock exhaust from manifolds back
Old Aug 29, 2005 | 11:36 AM
Wet 1's Avatar
I don't know Jack about F body exhaust systems, but cut out the cat and weld in a straight through bullet muffler. You shouldn't loss much if any performance and will kill some of the sound. It will cost you about $40 to try it.
Old Aug 29, 2005 | 11:47 AM
onfire's Avatar
Coal Mining Director
Dynatech make a stainless substrate cat....much more durable than a ceramic sub.
Old Aug 29, 2005 | 12:18 PM
boosted99camaro's Avatar
Originally Posted by Turbo LS1 SS
i have the sts kit.
or is there any other why to fix my problem.
I was thinking of getting an offroad pipe also but was worried about the noise
how has the performace changed does the turbo spool any different.
also what about a bullet muffler somwhere in the after cat pipe?
Old Aug 29, 2005 | 02:32 PM
spools up a little faster (maybe 500rpms), noticably more power under boost, not worth the sound under normal driving conditions.... thanks for the suggestions, keep them comin
Old Aug 29, 2005 | 02:46 PM
NYSS Guy's Avatar
I have the same bypass pipes, and it does get louder, and performs better. But, did you get the car re-tuned after you put them on? My tune was WAY off by just changing those pipes. Now are you worried about cops or you don't like the sound? If it's the sound, maybe a small muffler after the turbo. If it's the emissions stuff, than swap out the pipes when its testing time.
Old Aug 29, 2005 | 05:28 PM
DarkblueTA's Avatar
2 dyno max bullet mufflers after the turbo and your good to go
Old Aug 29, 2005 | 06:18 PM
socalstreetracer's Avatar
thats what im gonna do, 2 bullet mufflers. These sts kits are loud as a $hit!!!
Old Aug 29, 2005 | 06:19 PM
Zombie's Avatar
Ditto on this. It's what I have done, but both darkblueta and i have the same guy work on our cars The wastegate is also routed back in after the 1st muffler.
Old Aug 29, 2005 | 06:42 PM
do u guys have pics of this? obviously there's limited room back there, im at school away from my car, and i cant get a mental picture..... any pics would be appreciated
Old Aug 29, 2005 | 07:14 PM
Public's Avatar
Oh snap I'm about ready to do this myself, got pics? I was ordering a flex joint for the wastegate earlier. Where can I get a wastegate flange?
Old Aug 30, 2005 | 01:52 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I'm wondering about this on the gto, because there isn't any room behind the turbo. I want to delete the cats, but I don't like constant highway drone.
Old Aug 31, 2005 | 11:52 AM
Public's Avatar
Zombie I would still like to see a pic of your turbo setup!
