aluminum vs iron block
What I really want is an aluminum LS1 block because of the lighter weight (I think about 65lbs) because my car is already heavy. I'm worried about being able to hook up as well as having a good distribution for a good feel on the road. Do you think this weight savings is justified or should I go with the beefier iron block because of the higher boosted HP and torque and FI setup is going to produce?
But that even takes a back seat to the beef of my question... I could start my build right now with my iron block... but do you think it's worth the wait to find an aluminum block?!
I just question the decision by some f-body owners to trash the light gem of a block because the "think they might" need it.
Irreguardess of what is actually known.
Its nothing new in hotrodding though.
I personally went with a iron block due to the price.
For your power levels this should be fine. ProStock John and Harlan are making way more power than you intend to and have had no problems. They are both running stock cranks as well I believe with stock main caps with ARP studs!
Spend the money on a quality intercooler and the right sized injectors, nice exhaust, good tuner for your car.
Here is John's combo:
LS6 intake
stock ported OEM TB
stock crank
eagle 6.125 rods
diamond pistons, for 8.2:1 compression, a little sturdier than the off the shelf 9:1 ones
6.0 heads ported with GM MLS gaskets
Big supercharger.....
BigStuff3 (BS3) $$$
Mark
An iron block has less flex than an aluminum. Now that doesn't mean that your motor is gonna blow everytime you boost it. It does mean that its gonna move and has much more chance for diaster than an iron. Iron is cheaper, it weighs more, but if you don't mind the weight. Its the way to go for a budget build. I'm gonna run a C5R block on my setup, but its much more money to go that route.
