turbo controller
Old Aug 31, 2005 | 03:45 AM
ozzykicks2002's Avatar
Default turbo controller
I was looking at the turbo controller that STS has to offer and all it is a switch for 2 preset levels. I want to have a controller that will work from 1-10psi what ever i want you know? what controllers out there are good? any recomendations on a certain one?
Old Aug 31, 2005 | 03:57 AM
Boostaholic's Avatar
1psi is kind of low, lowest I have ever tried to run mine is 3
Old Aug 31, 2005 | 04:27 AM
Well ok im just saying for the matter of just saying that. . I just wanna see some cool turbo controllers out there that people like
Old Aug 31, 2005 | 04:51 AM
Eboost2 is a good one
Old Aug 31, 2005 | 08:04 AM
MTBDOC's Avatar
The STS controller is an electric switch that triggers a solenoid. Basically, you have two settings: the boost that your wastegate spring is set for; and a 0-5 or 0-15 psi manual control valve that feeds SOME of the boost to the backside of the wastegate actuator.
So, if you feed 3 psi to the back side, your boost at that point is wastegate + 3 psi. You have a manual valve that you can adjust by trial and error for your max boost. Then the switch controls whether or not you feed that pressure to the backside.
On my GTO, it will operate w/ a .6 bar spring [should see ~7 psi after intercooler]. Then, while tuning, we will dial in the manual valve at a SAFE level of power (don't want to break the pistons). At that point, I can run either ~7 psi or 10-12 or wherever we end up during tuning by flipping a small rocker switch.
Not real sophisticated, but they work. The eBoost2 looks awesome...as is the price!
Old Aug 31, 2005 | 08:27 AM
boosted99camaro's Avatar
I just use a cheap manual one
Old Aug 31, 2005 | 01:13 PM
WoW that EBoost2 controller looks awesome! does anyone here have it that is recommending it have it? is it pretty accurate? now just need to find the best place for the best price. . anyone know where?
Old Aug 31, 2005 | 02:45 PM
bump. . .
Old Aug 31, 2005 | 03:42 PM
2000 Tran Zam's Avatar
i think forcedinductions.com is the only place that I know of that carries them...
Old Aug 31, 2005 | 11:10 PM
Ordered the E boost 2 for my kit!
Old Sep 1, 2005 | 10:38 AM
SNEKATK's Avatar
Did you end up buying a kit?
Old Sep 1, 2005 | 11:18 AM
by kit you mean turbo then yes, got the STS kit with the GT-67 methanol, BOV the e boost 2, 42 injectors, racetronice fuel system pump
Old Sep 1, 2005 | 04:49 PM
SNEKATK's Avatar
Who did get your best price with, or did you not shop around? I'm looking to buy.. You can PM me if you'd rather with the info..
Old Sep 1, 2005 | 05:57 PM
I got the e boost 2 controller from boostcontrollers.com and talk to ted he hooked me up with a pretty fly deal I got the controller with the 2 led ring /w led (you get to choose you colors) and the dash mount kit all for like 639 =5 dollor shipping
Old Sep 1, 2005 | 06:13 PM
SNEKATK's Avatar
I meant on the Turbo kit.. I should have been more specific
Old Sep 1, 2005 | 11:29 PM
Actually I got the kit from sts they gave me the best deal There was a dealer in florida that was offering 10% off and tbyrne was also 10 off
Old Sep 2, 2005 | 09:36 AM
SNEKATK's Avatar
Are you planning to install it yourself? Or are you going to have a shop do the install?
Old Sep 2, 2005 | 01:31 PM
Me and my buddy are going to install it
