Which spark plugs for supercharge
Old Sep 10, 2005 | 10:11 PM
Fahad's Avatar
Question Which spark plugs for supercharge
My friend has Trans am LT1 and after he finished from building his engine with procharger so he wondering, which the best spark plugs for his engine?
Regards..
Old Sep 11, 2005 | 01:57 AM
DeltaT's Avatar
I like the plain Copper Champions. I do a little work on rounding down the electrode with a file, maybe 5 minutes per plug, gap 'em at .035" and you're good to go.
Plus, they're cheap, so you can change them for $10, less on sale.
I'm running the RC9YC, which is 2 steps cooler than stock. No fouling or other drama.
I have 2 friends with SS Camaros, blown (1 vorthech, 1 ATI) and they both use the same type Champions.
Jim
Old Sep 11, 2005 | 02:14 AM
ABeasst's Avatar
TR6 is a common plug run
Old Sep 11, 2005 | 02:28 AM
V8_DSM_V8again's Avatar
NGK BR8ES or BR7ES depending on heat range. I have had good results with the non projected tip plugs on forced induction.. A projected tip would be BPR8ES.
Old Sep 11, 2005 | 10:00 AM
95zpro's Avatar
NGK TR6 are a good plug to run!
Old Sep 13, 2005 | 07:49 PM
Fahad's Avatar
Guys, i really do appreciate your helps
Thanks
Old Sep 13, 2005 | 09:18 PM
Vax's Avatar
Vax
your choices are
denso iridium
denso iridium
denso iridium
hope this helps
seriously, they rule in FI apps, expensive per plug, but worth it.
Old Sep 18, 2005 | 12:07 AM
DeltaT's Avatar
I've heard these plug's only advantage is that they are more consistent over very high mileages, like 100,000+. I know their conductor is very small compared the the copper Champions. Why do the major blower companies recommend against the platinum and exotic metal plugs, at the same time they recommend adding an MSD ignition (or other CD)?
I may be missing something serious but I don't see why the iridium's rule in FI, and denso in particular for that matter. Any facts appreciated.
Jim
Old Sep 20, 2005 | 07:55 AM
oOoLy's Avatar
Hi fahad,
I have a good spark plugs for your frinde in Thai i will send it to you with sager and bader soon hahahaha
Old Sep 20, 2005 | 08:29 AM
WAHUSKER's Avatar
The BAD thing about platinum plugs is the tips fall off & get wedged in your combustion chamber. The good thing about Iridiums is they have a much better misfire rate. Does that justify $8-10 a plug? You be the judge. I'll be running TR6s.....
Old Sep 20, 2005 | 09:16 AM
Fahad's Avatar
That's right. do you mean this Iridiums NGK-7164??
oOoly. looool good luck
Old Sep 20, 2005 | 10:49 AM
Race-Prep's Avatar
Suspended Sponsor
Originally Posted by Vax
your choices are
denso iridium
denso iridium
denso iridium
hope this helps
I would be careful, we have seen noting but problems with the iridiums, they fail under severe loads and they also cause detonation problems, we have been able to give quite a bit more timing and gain SIGNIFICANT power in forced induction engines by going with the standard copper plugs like the RC9YC.
-Bryan
Old Sep 20, 2005 | 12:35 PM
V6 Bird's Avatar
Originally Posted by 95zpro
NGK TR6 are a good plug to run for an NA setup!
FIXED.
If you are using any sort of power adder, I recommend a NON projected tip at least 2 steps colder like the Champion Rc9yc's mentioned.
I personally run NGK R5671A-8's in my motor NA and 9's for the juice.
Mike
Old Sep 20, 2005 | 12:42 PM
V6 Bird's Avatar
your choices are
denso iridium
denso iridium
denso iridium
hope this helps
Let us know what your pistons look like when one grenades!
Old Sep 20, 2005 | 01:15 PM
Naked AV
Guest
Posts: n/a
TR6's 4 me.
