6.0 heads
Old Sep 14, 2005 | 03:26 PM
flippincamaro's Avatar
Default 6.0 heads
Hey guys what are people doing to 6.0 heads before they put them on? Are you guys changing anything on them before installing? I plan to run these on my iron block aswell. For now though on my 5.7 thanks guys
Old Sep 14, 2005 | 07:19 PM
mcmillion's Avatar
I did 918s on mine.
Old Sep 14, 2005 | 07:24 PM
69firebird's Avatar
Well what are your goals? Do you just want to do a 'budget thin' or are you wanting a more lasting idea?
If you are just using a stock block, and want heads for a lil lower compression, then yeah, just throw some springs on them.
If you are building a motor there is no reason to get cheap now, ports them springs,a nd possibly larger exhaust valves.
all in what you want to do
ed
Old Sep 14, 2005 | 08:09 PM
ddnspider's Avatar
i sent mine to HPE to get ported,new valves,seals, double valve springs,ti retainers.pretty much everthing needed for a full build.
Old Sep 14, 2005 | 09:36 PM
I would kinda like to go cheap now as these will be on my stock 5.7 for now then a iron block not sure yet though. I dont want to do to much to them and lose alot of power on my engine the way it sits now. thanks guys for the help what size exhaust valves should i use and should i leave the intake valves stock?
Old Sep 14, 2005 | 09:53 PM
Blown Ta's Avatar
i just put 918 on mine, other then that they are stock 6.0 heads. after i forge the bottom end ill prob. get them ported. i also put in a ls6 cam for now.
Old Sep 14, 2005 | 11:07 PM
cool thanks how do they pull stock?
Old Sep 15, 2005 | 04:17 PM
marine02ss's Avatar
Install comp 918's,get some bowl work done,ls6 camshaft
Old Sep 15, 2005 | 11:46 PM
As of now i have my patriot valve springs on my heads will these work on the 6.0 heads? Since everybody says to run 918s
Old Sep 16, 2005 | 08:06 AM
longrange4u's Avatar
I have 918s on mine... otherwise stock for now
