9:1 compression - what pistons to use?
Old Dec 4, 2001 | 01:59 PM
jhelms's Avatar
Default 9:1 compression - what pistons to use?
For a blower appliction for a friend of mine (99 LS1 H/C car).
His motor is fine right now he just wants to put in lower compression pistons - what all should he consider? He wants to run about 10 psi or so of Vortech aftercooled boost.
He's got the fuel system covered, does he need new rods too?
Old Dec 4, 2001 | 02:44 PM
Big Mike's Avatar
Default Re: 9:1 compression - what pistons to use?
I hear JE and Ross are really good pistons. While he has it apart I would change the connecting rods too!
Old Dec 4, 2001 | 05:14 PM
Nickn20's Avatar
rob raymer www.ls1motorsports.com has a package for a 1000 bucks, it comes with ross custom pistons pressed on to stock rods, rings, ARP bolts, all ya need to do is give back the stock rods as a core, its a sweet deal.
Old Dec 4, 2001 | 06:18 PM
ProModTA's Avatar
To lower compression you need to use a dished piston. JE or Ross can make these for you. I would recomend a set of H-beam rods. But that is my personal pref.
Doug
Old Dec 4, 2001 | 07:11 PM
jhelms's Avatar
One of the local shops recommended a set of Wiseco's for $499 and some Eagle SIR rods for $289, does that sound right?
Old Dec 4, 2001 | 07:24 PM
jhelms's Avatar
[quote]Originally posted by Nickn20:
<strong>rob raymer www.ls1motorsports.com has a package for a 1000 bucks, it comes with ross custom pistons pressed on to stock rods, rings, ARP bolts, all ya need to do is give back the stock rods as a core, its a sweet deal.</strong><hr></blockquote>
http://www.ls1motorsports.com/ls1cinteng.asp
Sounds like a decent deal, but I wonder what sort of boost level it will hold up to? What are the stock rods good for?
Old Dec 5, 2001 | 08:29 AM
Z00's Avatar
Z00
I'm thinking about the same package from Rob. I'm not planning on running a lot of boost as I'm trying to maximize the flow inside my engine. I am curious as to how much boost it will hold though.
Old Dec 5, 2001 | 10:18 AM
Rob Raymer's Avatar
[quote]Originally posted by jhelms:
<strong>
Sounds like a decent deal, but I wonder what sort of boost level it will hold up to? What are the stock rods good for?</strong><hr></blockquote>
John, this is a direct quote from my response to the email I received from you:
"It's not how much boost they will take, but rather how much detonation they won't take. The stock rods can handle roughly 700fwhp, and even more with the ARP bolts installed."
As you've all heard a million times by now, detonation kills. No matter which rod/piston combination you have.
These particular Ross pistons have 2 valve reliefs, and will lower compression to approximately 9.8:1. Though we can have them built to any desired compression ratio.
Hope that helps,
Rob Raymer
LS1 Motorsports
www.LS1Motorsports.com
"World's Fastest Forced Induction LS1"
9.94 @ 136.37 - '98 Z28 Single Turbo
 Michael S. Palmer
