FFHP T76 single turbo Corvette kit
Old Sep 23, 2005 | 01:42 PM
  #41
Demon SS's Avatar
Originally Posted by 69firebird
how long do you think before the F body kit would be started? Also if you were to guess how much for just the hot parts?
we are hoping that it will be started in about a month and a half. i hoping to have it ready by the first of the year.
  #42
Demon SS's Avatar
Originally Posted by Cobras_Rule
i wanna see pics installed
ask and you shall recieve
Old Sep 23, 2005 | 01:43 PM
  #43
Demon SS's Avatar
Originally Posted by 00TurboT/A
nicw kit looks like it would be crimped in the engine bay
hopefully the new pictures will show that it really inst that cramped.
Old Sep 23, 2005 | 01:47 PM
  #44
Demon SS's Avatar
Originally Posted by smokinHawk
wow that would be awsome a kit with no vette tax
what size is that up-pipe/ y-merge. is that 3", it seems a git bit.
might gain some clearance if you switched to 2.5", heck there are guys making 1500hp with a 2.5" merge.
nice kit very inovative.
but ya id hate to change those spark plugs. Hopefully the downpipe is as easily removable as you said.
the all the hot pipe is 3 inch. the down pipe is 3 inch and the splits to twin 2 1/2 and routes to the stock exhaust. the 2 1/2 hot pipe is something we are going to try when we dyno the car. we may switch the pipes over and see what kind of spool and hp difference there will be. the spark plugs really arent that bad. the down pipe is very easily removable. the header primarys are 1 3/4 o.d and 1 5/8 i.d.
Old Sep 23, 2005 | 01:49 PM
  #45
Demon SS's Avatar
Originally Posted by 99SS-T
I dont think your exhaust cooler is gonan get the rave reviews you are hopin for. lol. Looks how GL
John
minor issue that has already been resolved. we are having a custom upper hose made that will not be affected by the heat.
Old Sep 23, 2005 | 01:50 PM
  #46
Demon SS's Avatar
Originally Posted by 2001WS6Vert
What size is that primary header tubing? It looks large.
the primarys are 1 3/4 o.d. and the i.d. is 1 5/8.
Old Sep 23, 2005 | 01:52 PM
  #47
Demon SS's Avatar
Originally Posted by XJGPN
Based solely on pics of this kit and having seen the Cerra kit in person (both uninstalled and installed) I can say they are not similiar at all. The Cerra kit was a very basic (and quite frankly ugly) Log manifold setup that made the QMP kit look like a work of art. This setup... while it looks like you will have to relocate many more items also is a much better design from a power producing standpoint.
you dont have to relocate many things at all. only the ALT. has to be moved and the radiator bottom moved forward about 4 inches.
Old Sep 23, 2005 | 01:53 PM
  #48
Demon SS's Avatar
Originally Posted by CHRISPY
Looks awesome!!! If you can do it for under 5K I'd be in for sure
Including a blanket with the turbo?
a turbo blanket will be included with the kit. we are trying to cut out as much heat as we possibly can.
Old Sep 23, 2005 | 02:00 PM
  #49
Demon SS's Avatar
sorry about making so many posts. if i forgot to answer any questions let me know.
Old Sep 23, 2005 | 02:55 PM
  #50
69firebird's Avatar
I know those headers would come out right where the power steering pump is on an F-bod
Old Sep 24, 2005 | 04:23 AM
  #51
Watch22's Avatar
How is this going to mate up to the existing stock exhaust? It would be really nice to somehow hook up to the stock locations.
Thanks
Old Sep 24, 2005 | 08:18 AM
  #52
LSONE's Avatar
Thanks
if you look at the second attachment, you'll see the down pipe, which i would imagine continuesd on to hook into the stock exhaust.
Old Sep 24, 2005 | 10:00 AM
  #53
Demon SS's Avatar
Thanks
the down pipe goes down and splits into two 2 1/2 inch pipes and does connect to the stock locations.
Old Sep 24, 2005 | 10:58 AM
  #54
Jaegermeister2k's Avatar
And after the 2 stock locations it goes back into 1 pipe again? Wouldn't it be better to make a 3" pipe from the turbo all the way out the back with a bullet inbetween?
Old Sep 24, 2005 | 11:22 AM
  #55
LSONE's Avatar
i doubt thats gonna fit on a vette, and the vettes have a "dual" exhaust stock anyway, so if you plan on running a catback you will need to use this setup.
Old Sep 24, 2005 | 11:53 AM
  #56
Ok. I'm retarded. I was thinking of the fbody's.
Old Sep 24, 2005 | 12:34 PM
  #57
red90cobra's Avatar
cool deal. gives me a few ideas. how much are the hot parts?
Old Sep 24, 2005 | 10:12 PM
  #58
NoOne's Avatar
Programming for the alternator?
I am pretty sure that if you swap out the alternator alot of things in the PCM need to be changed since the PCM monitors alt output and you need a specific unit for the C5. You'd lose alot of the PCM monitoring for voltage.
If it all fits I think its great.
Old Sep 24, 2005 | 10:18 PM
  #59
yellow04gto's Avatar
redline motorsports makes a single turbo kit for the c5 but they advertise a pte 70... and they only install the kits...they won't ship them complete
Old Sep 24, 2005 | 10:44 PM
  #60
XJGPN's Avatar
I hope that didn't come off as an insult... The cerra turbo setup was very compact. It appeared less intrusive (probably not the best choice of words.. makes it sounds like I prefer it in some way, which is absolutely not the case).. whereas yours just seems "bigger" in all dimensions between the long seperate primaries and the routing of everything up top whereas the Cerra kit used a tiny restrictive poorly made log.
