procharger seals
Old Sep 26, 2005 | 05:56 AM
BLWNZ06's Avatar
Default procharger seals
anyone know where to get the seal that goes behind the pulley.. or have a part# or size?
Old Sep 26, 2005 | 06:09 AM
EPP's Avatar
EPP
Give ATI ProCharger a call at 913 338-2886 and ask for their tech department. They can send one out to you, or you can call us at 260 483-9300 and we can get it for you. Bob
Old Sep 26, 2005 | 08:26 AM
Ponyhntr's Avatar
No, they will not sell the seals. You would have to send it in to them to have it repaired.
Old Sep 26, 2005 | 12:07 PM
Wet 1's Avatar
http://forums.corvetteforum.com/show...01&forum_id=86
Old Sep 26, 2005 | 09:51 PM
618HAWK's Avatar
Is it normal for the internals of a D1SC to become some what pressurized? The last oil change I had a "Blow Out" IE mess when I removed the drain plug. And just yesterday noticed light oil flim around lower section of head unit.
Old Sep 26, 2005 | 10:41 PM
hellbents10's Avatar
LS1Tech Sponsor
typical, time for new seals lol.
Old Sep 26, 2005 | 11:42 PM
kp's Avatar
kp
As I stated on CF I have yet to see a P1SC or D1SC that doesnt seep a little, especialy right after a long drive or a day at the track. There is a lot of pressure build up there. I'm talking like a drop that will accumulate on the bottome of the housing overnight, not filling up a pipe or leavng spots on the floor, if its that bad something is wrong naturally.
If you have your breather hooked up to the inlet hat you will also get some engine oil seeping out since it will collect in the housing and seep through. Easy to tell if its that oil because it will be black, of course if your breather isnt hooked up to the blower inlet you wont engine oil there. There is no seal where the housing is attached to the gear case/impeller so anything that gets in there seeps out after a while.
Always loosen the fill plug and relieve the pressure before taking out the drain plug if it has been run recently, otherwise it will puke out 4oz of oil in like half a seciod LOL.
Old Sep 27, 2005 | 12:15 AM
HUGGER ORANGE SS's Avatar
Always had issues with a little weeping of my blower...
My P-1SC was worse than my D-1.
It's really only bad after a long cruse or a long drive...
Clint
Old Sep 27, 2005 | 06:58 AM
Wet 1's Avatar
I never had any leakage (internally or externally) on my P1SC or even the D1SC. Pipes and IC were bone dry when I open things up.
Old Sep 27, 2005 | 05:19 PM
Are you pushing yours to 15psi though and 61,000 impeller rpms?
Old Sep 27, 2005 | 05:33 PM
Wet 1's Avatar
Never checked the speeds. The P1SC never went past 13 psi, the D1SC went higher. Maybe I just got lucky with mine, but both were always dry.
Old Sep 27, 2005 | 10:25 PM
BLWNZ06's Avatar
if anyone needs a seal the part# is cr11625. they have them at applied.com part#ma1426139
Old Sep 28, 2005 | 03:47 PM
ta12sec's Avatar
Any one know where i can get an impeller for a d1?
Old Sep 28, 2005 | 04:46 PM
Ponyhntr's Avatar
That you would need to contact ATI about that...they make them in-house. I'm pretty sure you would need to send in the blower for an impeller replacement also.
Old Sep 29, 2005 | 07:39 AM
moehorsepower's Avatar
Default ATI Parts
Prochargers are a hit and miss, I have gone through 3 prochargers and had two of them rebuilt twice, Problems: Oils seeping into the intercooler, behind the pulley, and the impeller spinning on the shaft, All bearings going south, And NO, ATI WILL NOT SELL YOU ANYTHING but a belt........
Old Sep 29, 2005 | 08:38 AM
LS1Tech Sponsor
Right on, my freinds fullsize is at 14psi right now and he will go through a once of oil every 1-2 weeks. It leaks like whoa, typical I guess, most I have seen at least weep a little oil. The blower sounds great though. Its time for a D1 upgrade anyhow.
Old Sep 29, 2005 | 08:54 AM
kp's Avatar
kp
1oz every 1-2 weeks is what I would consider severe enought to send back and get fixed
Old Sep 29, 2005 | 09:06 AM
LS1Tech Sponsor
So do I, he is just waiting till the end of the season. I know its horrible to say the least. We do not have all season to have fun He will be sending it in sometime in oct.
