Upping boost to 10 psi
Old Mar 9, 2002 | 04:05 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Upping boost to 10 psi
Ok well whenever I get it out of the shop that is <img src="gr_images/icons/wink.gif" border="0"> . Having timing droped 2 at wot. It should put me at 17 i think. I was running 19 before i sent out the comp(still stock tuning). I can run 7psi on the street with 94 octane but I figure that is getting close. So 10psi will probably be a track only type deal unless i can find a place that sells 100 out here.
Old Mar 9, 2002 | 05:22 PM
y2khawk's Avatar
Default Re: Upping boost to 10 psi
Good luck <img src="gr_stretch.gif" border="0">
I was able to run 10+ on 100 octane and 16° mid range, then ramping to 21° by 6200
And from what i've found so far in the motor, things were doing well. <img src="gr_grin.gif" border="0">
Old Mar 9, 2002 | 06:04 PM
Cool28's Avatar
Thats good to hear <img src="gr_stretch.gif" border="0">
Old Mar 9, 2002 | 06:08 PM
y2khawk's Avatar
I'm guessing 10 is ok, but i was pushing over that on many occasions.
I've tested the durabity of the head gaskets, and i was getting close to the edge <img src="gr_stretch.gif" border="0">
http://harlan.sketchy.net/teardown/107-0709_IMG.JPG
http://harlan.sketchy.net/teardown/107-0713_IMG.JPG
funny thing is, it was only the middle cylinders. And i never got into the coolant. Oh well <img src="gr_grin.gif" border="0">
Old Mar 9, 2002 | 07:45 PM
Mark C's Avatar
[quote]Originally posted by Cool28:
<strong>I can run 7psi on the street with 94 octane but I figure that is getting close.</strong><hr></blockquote>
Do you know what your power level was at 7psi? Either that or the mass flow?
I am really close to giving Cartek a call to get larger injectors, up the boost to 6.5 - 7, and have them tune it with thier LS1 edit.
Old Mar 9, 2002 | 08:05 PM
Cool28's Avatar
I dont know the hp numbers but its hella fun when you hit the gas <img src="gr_stretch.gif" border="0"> . I'm running about 75psi(fuel press) at full boost. I figure anyway. Ordered my FP gauge today <img src="gr_stretch.gif" border="0"> . I also have #42 injectors. Which I think should be a must. I think 10psi and #42 injectors will be fine for my car.
Old Mar 10, 2002 | 08:35 AM
SJH's Avatar
SJH
I was ramping up to 28' with 10psi on the topend and starting with 24' with 7psi in the midrange.Stock compression.
Water/alky system <img src="gr_images/icons/wink.gif" border="0">
Steve
Old Mar 10, 2002 | 07:28 PM
Terry Burger's Avatar
At least you know if anything goes wrong with the turbos you can quickly get them replaced under warranty...
Old Mar 10, 2002 | 07:55 PM
Cool28's Avatar
WOW what would we do without you <img src="images/icons/rolleyes.gif" border="0">
Old Mar 10, 2002 | 08:11 PM
y2khawk's Avatar
