Turbo size / cubic inch?
Old Sep 27, 2005 | 11:54 AM
9kredline's Avatar
Default Turbo size / cubic inch?
Been reading this site for quite a while, just haven't posted much. I've have my '02 LS1 (stock cubes) sitting on the crossmember of my '91 300ZX slicktop, and to keep with the twin-turbo history it's the course I decided to go. I've been reasearching and came to a few conclusions but here's my question:
If my goal is ~500 crank horsepower (with room for a little growth over time), what turbos will provide the quickest spool?
I've been told two things on various forums thus far:
Turbo from an 86-87 Intercooled GN
and
T04e 50-trim
Can anyone else provide me with any more options? I've got the fuel, routing, and management settled, just not sure on turbo model/sizes.
Old Sep 27, 2005 | 12:01 PM
LSONE's Avatar
Damn man, that sounds sick. I see you're over in tampa, I'll have to check that out when you finish
sorry i couldnt help with turbo size
Old Sep 27, 2005 | 12:09 PM
FastKat's Avatar
If you only want 500hp at the crank, a twin turbo setup would probably not be in your best interest as far as "bang for the buck" goes. However, I have also been told that a pair of the GN turbos are suitable for an LS1.
Old Sep 27, 2005 | 04:07 PM
9kredline's Avatar
If I'm still in the area when it's done, no prob!
I understand completely. I'm just looking at that as a conservative, low-boost application on a stock block without dished pistons.
Okay, now my cheaper option is reputable!
Any other input is more than welcome.
Old Sep 27, 2005 | 06:09 PM
Paulz2820's Avatar
a 346 like you have as is will make 500fwhp easy with a cam and a set of heads. you swap pistons and rod bolts out (and heads) and could make 650 and beyond with those turbos
Old Sep 27, 2005 | 08:26 PM
9kredline's Avatar
That's what I've been hearing, that those turbos have a lot of potential on these blocks.
500fwhp
Front wheel drive? What's that?!
lol, I know, flywheel. Yuk yuk yeah...
Old Sep 27, 2005 | 10:04 PM
MIGHTYMOUSE's Avatar
precision makes a pte-63mm which is good for up to 700 crank hp i believe
Old Sep 27, 2005 | 10:32 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
For 500hp, a small 61mm unit will do the job and still give you a bit of room. Also it will spool extremely quick.
Jose
Old Sep 28, 2005 | 05:43 AM
9kredline's Avatar
Jose
I must be misinterpreting... Or would those be two turbos with a 61/63mm compressor housing? Because when I looked up 61mm units they show a rating of ~680hp potential from each unit, and that's way to big...
Correct me if I'm wrong!
Old Sep 28, 2005 | 08:06 AM
LS1TECH Sponsor
That is single system. Twins with those units would be insane...lol
Old Sep 28, 2005 | 11:05 AM
9kredline's Avatar
lol, that's what I thought. I'm just trying to stay away from large singles to help reduce spool time and have more streetable horsepower.
Old Sep 28, 2005 | 12:31 PM
Paulz2820's Avatar
fwhp=flywheel horsepower
Old Sep 28, 2005 | 12:46 PM
xXxSilveradoxXx's Avatar
I'm doing the same thing. I was gonna have to weld up some custom headers so I decided just to make it a twin turbo. Man, that is gonna be one hell of a ride.
GN=???
Old Sep 28, 2005 | 04:50 PM
9kredline's Avatar
GN=???
Grand National, the 80's turbo Buick.
That's the route I've decided on going. On the Buick V6 I've seen the turbo crank out ~350hp as a single unit with ~22psi, but I'm going to run that high until the motor requires a rebuild and I replace the bottom end.
Nice to see you from 3ZC.com
lol I know. ^^^ was just playing
Old Sep 28, 2005 | 05:21 PM
LS1TECH Sponsor
Here's my little GN....
Old Sep 29, 2005 | 01:20 AM
1CAMWNDR's Avatar
My God that is a nice car
Sorry, back on topic..............
