Building a supercharged motor from scratch.
Old Apr 24, 2002 | 09:40 PM
2001WS6Vert's Avatar
Default Building a supercharged motor from scratch.
I melted a piston and scored the cylinder. I want to do my homework so as not to screw up again. I am trying my best to keep the price down. Up towards $50,000 in a Trans Am is getting ridiculous. I don't know if my block can be salvaged. I am going to have a machine shop examine it. Valvegod has new LS1 blocks for $550.00 or the late 2001-02 for $800.00. I have an 01 and think it is the earlier one (I'll have to check the casting number. Is anything to be gained by changing to the later one? I definitely am going with forged dished pistons with ARP rod bolts. Do you think I should get aftermarket rods? Should stay under 600 HP and 6500 rpm. I will get the head studs too. Is there a better head gasket I should get? I am going to improve the heads + cam. I heard the 6.0 head is a good economical choice. Should I port them? I heard that they reduce compression so maybe I should not get dished pistons. Any cam recommendations?Any other th <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> ings that I should look into? Any good machine shops near Cincinnati that are familiar with the LS1 and have the equipment to help.
Old Apr 24, 2002 | 10:04 PM
VINCE's Avatar
Shorty Director
Default Re: Building a supercharged motor from scratch.
I was in the same situation as you.. I am having a new shortblock built with forged pistons with valve reliefs.. All the stuff you mentioned above as well.. Later I am purchasing a set of 6.0L heads and have them ported and polished.. I want my compression between 9.1:1 and 9.5:1.. I am planning on getting around 600rwhp as well. I am going to run NA for a while until I get the money saved for the FI project.. I am sure someone in your area will chime in about a local shop. If not it would be worth it to take the car to a reputable place and let them build you a setup with a warranty.. FI on a ls1 is still new. So you are going to have to play it safe until more knowledge is known.. Or you will be in the same boat again..
Old Apr 27, 2002 | 05:53 AM
Black LS1 T/A's Avatar
Moderator
A for what RPMs to keep it to, The lower the RPMs, the easier it is on your tranny. Of course, then torque becomes a consideration. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 27, 2002 | 01:05 PM
gogogadgetcar's Avatar
sounds like we're in the same boat I put two cracks in a cylinder wall and shattered a piston.
I just bought one of the newer blocks from valvegod (he's a cool guy) for 800 I never could get an answer on how much of an improvement it realy was over the older models on the forumns but v.g. told me it had better low-end breathing which helped make a little more hp and rev faster. I just figured newer was better so dished out the extra $300.
Old Apr 27, 2002 | 02:28 PM
VINCE's Avatar
Shorty Director
2001's have shown to produce more power, but it could have just been the intake..
Old Apr 27, 2002 | 08:30 PM
I think now that I will extend the R.P.M. range to 7000. I'm looking at the head/cam thing now--its very complicated. It also seems like there is more imformation for a N/A motor out there than a F/I motor. If modifications have to be made to the trans., converter or rear end so be it. I just want to put this thing together right and want it to be a killer set-up. I am staying at 350 C.I. though.
Old Apr 27, 2002 | 09:08 PM
VINCE's Avatar
Shorty Director
I would build the motor to take FI first and then get the blower. Yes, doing it right the first time pays off.. I know.. I should have built the motor long time ago when I first wanted to go FI, but I was talked out of it. No biggie, I will do it right this time.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 1, 2002 | 07:12 AM
I wish I had done it that way, but I supercharged the motor first, blew up the motor second, and built the motor third. Ha Ha.
