high boost top end miss?
changes were spark dwell up to about 6ms up top and ar94 plugs gaped at .028 or whatever it was they came at.
http://www.1320video.com/videos.php
i am running cometics, arp head studs and afr225 heads. strait 114 leaded fuel with the meth left on. a/f ratio was around 11.7-12.2 the entire run. timing at 14deg max. the logger showed a 1.8deg kr hit about the time the gasket blew out and another little bit of kr right at the very end of the run. i was shooting for 12.0max on my a/f but ended up a little higher than that.
my next trip down the track i am going to dial in 11.5/1af max and i will be running some of those titan copper gaskets. not sure what else to try.
better traction would be nice. i am running 4 305/45/18 nittos and warming the rear. presure is down around 15 in the rear and 18 in the front. the truck was hauling *** on that run. first ever 110 in the 1/8 and at the 1000mark i was online to run better than my 10.08 previous best but the power fell off before the end of the run.
On your a/f ratio. How much correction is allowed during a run? Is the MS adding or subtracting fuel at wot? Who makes the fuel you are running?
Kurt
i suppose i should try and get ahold of some c16 but that stuff is hard to come by around here. this isn't going to be a "normal" tune for me. i seem to be able to run mid 10's on pump(with meth) and that is where i am going to set it once/if i get this 9 out of the way.
next trip to the track will be in KC, i seem to hook at least .05 better there.
Kurt
Right now there is no EGO correction running at WOT. We were editing the VE table by hand based on datalogging the FJO wideband...
in hindsight, we could have turned the EGO targeting on - but for Drag Week, we were using EGO correction at low loads to improve mileage, then just making sure the AFRs were more in check during the runs.
the spark plug also broke, and banged up the exhaust wheel pretty good. hopefully your cylinder is ok.. mine was.
awesome truck
