high boost top end miss?
Old Nov 8, 2005 | 05:19 AM
  #121
smokinHawk's Avatar
dang that sucks, those heads are expensive.
did your logs show detonation, looks like the chamber on the head is spotted.
Old Nov 8, 2005 | 06:09 AM
  #122
69firebird's Avatar
did it just melt there, or did the turbo get some stuff through it as well?
it looks like where it burnt though you should be ok, as in its not as bad as it could have been
Old Nov 8, 2005 | 06:18 AM
  #123
parish8's Avatar
single digit dreamer
i had a spot of KR at the launch when i was pealing out and another at a shift, both under 2deg and when things are bouncing around i dont really trust those sensors. then about mid 3rd there was one spot of kr up to 1.8deg. i didn't hear anything. i am prety sure i didn't have good enough fuel or enough of it.
Old Nov 8, 2005 | 06:57 AM
  #124
Brains's Avatar
Oh man, that really stinks I was really hoping it was just a gasket, and you'd be back on the road...
Old Nov 8, 2005 | 07:06 AM
  #125
1320Video's Avatar
Old Nov 8, 2005 | 09:58 AM
  #126
dieselgeek's Avatar
Originally Posted by hellbents10
You said it was running ok like this?? Was it loud like a bad exhaust leak. If not, I wonder if that injector quit all together, cause the problem and then did not fire afterwards. Thus no horrible exhaust noise and super rich idle with a down cylinder. Sucks though!
Just saw the nice pics. Ouch. Gonna have to go to Jim's after work tonight and witness the damage firsthand!
Unless there was an issue with the power or the connector at the injector, if the injector stopped firing I'd expect the other 3 injectors on that bank to do the same...
It was a cold day, but humid. Still good for making power. I wonder if we didn't lose some water/meth pressure? AFRs weren't super great but again not all that bad, unless we missed something.
-scott
Old Nov 8, 2005 | 10:12 AM
  #127
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Originally Posted by parish8
i am running cometics, arp head studs and afr225 heads. strait 114 leaded fuel with the meth left on. a/f ratio was around 11.7-12.2 the entire run. timing at 14deg max. the logger showed a 1.8deg kr hit about the time the gasket blew out and another little bit of kr right at the very end of the run. i was shooting for 12.0max on my a/f but ended up a little higher than that.
What size injectors, what fuel pumps? Were you at the 1000rwhp level or less?
Old Nov 8, 2005 | 11:40 AM
  #128
NA$TY-TA's Avatar
Damn Jim that sucks...... Id did that before on stock 98 heads.... destroyed the head and the block......
You really thinking about selling the truck???? I know u didnt post that here but thats what i heard....
I dont know if id trust the block after that. Did you check the other head?? Turbo ok??
Kyle
Old Nov 8, 2005 | 02:57 PM
  #129
MIGHTYMOUSE's Avatar
looks familiar. i was able to get my cyl head re welded for like 40 bux at a local shop, my block didnt look as bad, but right around the cyl looks good on yours, and i wouldnt be surprised if it sealed fine (mine did)
i was on a 20 psi pull on pump and meth, 144.6mph when it bit me. i was happy it was a relatively cheap and easy repair.
Old Nov 8, 2005 | 04:21 PM
  #130
parish8's Avatar
96's, twin 340m's, probably 1100+rwhp based on 5000lb's and 110mph in the 1/8th. i log my fuel presure and it didn't drop, my a/f didn't drop either but it was a little higher than i was shooting for.
i am sure it was a combo of not quite enough fuel and not good enough fuel. no one to blame here but me.
Old Nov 8, 2005 | 04:23 PM
  #131
LS1Tech Co-Founder
114L + Meth is like what TwnTrboCe runs, maybe it was not enuff issue. Or an injector locked up?
Old Nov 8, 2005 | 04:26 PM
  #132
parish8's Avatar
not sure buy my next trip to the track will be c16 and 11.5 max. since it was the typical #7 i am going to say it isn't an injector problem. i was just too close to the edge and that was(and always is) the first cylinder to go.
Old Nov 8, 2005 | 06:10 PM
  #133
hellbents10's Avatar
LS1Tech Sponsor
Right on sounds like it could be it. C-16 and a 11:1 AFR should keep you away from that. Good luck on getting her back out soon.
Old Nov 8, 2005 | 06:12 PM
  #134
NA$TY-TA's Avatar
can that head be fixed????
Old Nov 8, 2005 | 06:38 PM
  #135
parish8's Avatar
hope so. other wise i just turned $1100 worth of alumimum into about 3$ worth.
Old Nov 8, 2005 | 10:17 PM
  #136
NA$TY-TA's Avatar
If you did will AFR sell just one head...... Im i hope it didnt ruin it....
