do your engine temps go up under boost?
Old May 29, 2002 | 09:10 AM
thunderstruck's Avatar
Default do your engine temps go up under boost?
i have only had the t-60 turbo on for about 3 weeks now, and havent been at wot much. the other day i did, and the engine temp went up to 210 very quickly. i let off the gas, and it slowly went back down to normal. is this common?
98 camaro, no programming yet
Old May 29, 2002 | 01:38 PM
Default Re: do your engine temps go up under boost?
Does your temperature go any higher than 210 if you stay at boost longer?
Old May 29, 2002 | 02:02 PM
cablebandit's Avatar
I think thats about where they go under a 1/4 mile run. Now keep in mind I start out at some prettu cool temps to start with....like 150-160. My new motor NOT under boost...just cruising is running 225-230 so i think you are just fine
Old May 29, 2002 | 08:43 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
mMine use to do that. Till I pretty much sealed the rad so air would go in there only instead of the engine bay. Also got a 180 thermo to help. The key is sealing the rad so it gets more air from the bottom.
Old May 30, 2002 | 12:51 AM
Mine does with the t-76 kit
Old May 30, 2002 | 01:56 PM
thats what i have been thinking too... im looking for a way to see if i can move the intercooler toward the front of the car more.
Old May 31, 2002 | 12:02 AM
MIGHTYMOUSE's Avatar
it is prolly cuz of the front intercooler blocking airflow, long as the fans cut on at 210, and it stops rising, its all good.
i never saw mine ever get higher than 210 on street or making a pass, with the 160 stat and fan settings... 12,13 psi boost at times
