ATI LS1 Pulley Sizes and Advertised Boost?
Moderator
Re: ATI LS1 Pulley Sizes and Advertised Boost?
It will all vary, based upon all we've discussed above.
I'm just telling ya'll what the spec sheet that comes with the Installation Manual says. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Sounds like I'll be using the 3.20".
Anything smaller than that made by ATI.. just for curiousity??
Moderator
Not that I know of, for the P-1SC and the D-1SC.
Be careful... at sea-level and no headers I was at 12 PSI of boost with the 3.2" pulley! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
With headers, it dropped to 10 PSI, but I still had to keep TORCO in it or mix 100 Octane when I raced.
It may drop the boost down some more with the bigger cubes of the 422 and heads/cam change (I don't know). I'd be more comfortable running 7 or 8 PSI... 9 max.
Thx. I have the LS6 Intake, Super Long Tubes, True Dual, Hi-Flow Cats, ported TB.. also am cammed. I'm just guessing I'll see lower than full stock boost.
Whatcha think I'd see with the above & 3.20"?
May be signing a contract this week for a project that would cinch my D1-SC. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
black ls1 with which blower did yoiu see this. ati dies have a 3.0 pulley and belt. i talked to them today.ts supposed to be 9 psi but ill prolly see 6 to 7
Ati standard kit 3.4.. upgraded to 3.2
all stock except for grot 1 7/8 headers and addition of bosch 36# injectors.. using ATI add on fuel pump..
I see 5# before 4k rpm, 10# by 6250 rpm.
check it out @ 10thanvhawk web site
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by scott ws6:
<strong>black ls1 with which blower did yoiu see this. ati dies have a 3.0 pulley and belt. i talked to them today.ts supposed to be 9 psi but ill prolly see 6 to 7</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">D-1SC
The specs came on a check-off sheet with my kit I bought last year. Things can and do change. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'm not doubting your information, just saying what I know. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
I could post that page of the check-off sheet , if you like. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
There is also different sizes in the 8 rib belt setup too. They make a 3.0 inch pulley also in 6 rib. I ordered a 3.7 inch 8 rib and they said it was a "12# pulley". I think my crank pulley is larger than the regular ATI kit, as I have the GWP stage 3 setup.
Moderator
Jason did tell me if my boost dropped lower than I'd like after I get the GWP 422 motor, if I went to the 8-Ribbed pullies and belt, I could get a larger crank pulley to increase boost and control slippage.
Moderator
I will probably be right at the limit of my D-1SC's capabilities with the flow of Kenny's 422. I'm glad I'm in the low-country, or it could certainly be a big challenge. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck on your setup!
#32
mike, yeah i talked to them today and they sent the 6 rib 3.0 pulley and oil to me. I was going to upgrade to the d1 and the 8 rib but with the 9-1 cr 355 that cartek is building im just going to save a little more and get the F1.
#33
Moderator
<strong>mike, and how do i get on the list for my blower runs from last year. i left a post for you on the 5 page post.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You in! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Congrats!
