SDCE and a Smaller Blower Pulley
Old Oct 5, 2005 | 11:36 AM
Ed Blown Vert's Avatar
Default SDCE and a Smaller Blower Pulley
I am currently running the SDCE with a 3.4 blower pulley.
Does anyone make a smaller pulley like a 3.2? Any other option to get my boost up from 7#?
Old Oct 5, 2005 | 11:39 AM
Blackbird's Avatar
have you done the math?
won't you overspin the blower quite a bit with the 3.2?
Old Oct 5, 2005 | 01:14 PM
With the SDCE pulley (7.25) and a 3.2 blower pulley spining the engine to 6500. I will spin the blower to 60k, max is 65k
Old Oct 5, 2005 | 01:18 PM
Blackbird's Avatar
hmmm I wonder if they use a smaller crank pulley now?
I could have sworn when I had mine a few years ago a 3.4 would have just about maxed out the blower by 6000rpm.
well yah it sounds like you need a 3.2 then.
ASP can make it for you if you can't find any used ones.
Old Oct 5, 2005 | 01:24 PM
Unless my calculations are wrong.
Crank Pulley / Blower Pulley * 4.10 * engine RPMs
7.25 / 3.2 * 4.1 * 6500 = 60,378
Old Oct 5, 2005 | 03:06 PM
kp's Avatar
kp
sorta
7000rpm and 3.4 with the 7.25 SDCE crank is about max for a D1SC (62K max).
A P1SC-1 is rated at 65K so at 6500rpm a 3.2 pulley will just be fine. Even though after 58-59K or so a P1's peak boost doesnt increase a whole bunch in my experience.
Old Oct 5, 2005 | 03:24 PM
Just have to find one.
Old Oct 5, 2005 | 03:57 PM
kp's Avatar
kp
ASP or riechart will make one, may call ATI and see if they sell a 3.2 8 rib. Bob at EPP is a good guy to deal with for ATI parts if you dont want to deal with the friendly staff at ATI
Old Oct 5, 2005 | 04:00 PM
stevieturbo's Avatar
ASP can make em.
Ive had them make me a few different sizes for my Vortech. Usually about 4 weeks from placement of order til I received them, and I'm in the UK.
Old Oct 5, 2005 | 04:33 PM
I will fire off a PM to Bob. And check with ASP. How do I get in touch with riechart ?
Old Oct 5, 2005 | 04:48 PM
618HAWK's Avatar
I was on the phone with ATI just this morning with other issues. Asked how small they went for the 8 rib. Was told 3.4
Old Oct 5, 2005 | 04:55 PM
Thanks. I fired off an email to ASP.
Old Oct 5, 2005 | 05:29 PM
kp's Avatar
kp
reichardracing.com
I would advise calling them or ASP on the phone, never had either answer an e-mail for long time..
Old Oct 5, 2005 | 06:23 PM
Spdmn75's Avatar
Off subject question but with a 3.4 P1sc, how much power increase would you guess on converting this to a D1sc with the 3.4?
Old Oct 5, 2005 | 06:24 PM
Originally Posted by kp
reichardracing.com
Thanks.
Old Oct 6, 2005 | 12:34 PM
Well ASP just got back to me and can make me anything I want.
What would be the smallest I could run with the SDCE?
3.0"?
Old Oct 6, 2005 | 05:38 PM
LSs1Power's Avatar
You can always go with a larger crank pulley. Try the 7.65 that comes with ATI 8 rib kit. That should put u close to maxing out the D-1SC with the 3.4 SC pulley around 6500-6700RPM.
Old Oct 6, 2005 | 06:19 PM
Yep, the 7.65 with a 3.4 would max out my P1 @ 6500. But will it mount up to a ATI Damper?
Then again, I don't thing the belt will clear my EWP. It barely clears now.
But I would rather go with a large crank pulley if it will work.
Old Oct 6, 2005 | 06:28 PM
618HAWK's Avatar
I am currently running the 7.65 8 rib crank pulley with a 3.7 on my D1 seeing a good 8 and close to 9psi. @ 62-63k Granted you have a bigger motor though., vs my stocker. The 8 rib crank pulley mounts directly to the ATI superdampner, with no problems.
Chris
http://i3.photobucket.com/albums/y65...install069.jpg
Old Oct 6, 2005 | 06:51 PM
Chris
Sweet! Now to see if it will clear my EWP.
Are you running the SDCE tensioner?
