DIY Kit vs Premade kit (not a typical thread)
Old Oct 5, 2005 | 02:01 PM
black_z's Avatar
Default DIY Kit vs Premade kit (not a typical thread)
Ive been heavily researching a DIY turbo kit for the past month or 2 and from looking at prices for everything new, it seems as though I would hardly save any money, (if any at all) by going the homemade route, even with mild steel. I want to make ~500-550 to the rear wheels for a while. I would be going with a truck manifold build, and can get the manifolds for basically nothing, but it still seems to pretty much equal out to what Hi-flo and groundzero are asking for their base kits with me doing all the work myself? Am I adding things up incorrectly?
Turbo-1200
Wastegate-400
BOV-250
Mild steel tubing-500
couplers, fittings, collectors, supplies, oil lines, odds and ends-1500
FMIC-500
I know im forgetting things, anything I missed? Im off to class.
Old Oct 5, 2005 | 02:08 PM
Camaro_Zach's Avatar
this is identical to ever other thread of its type haha..
do you have a welder? do you have experience using the welder? dont think you can get some $100 welder off ebay and just "use it". honestly. id say approx 4g in equipment if you dont have it. 1500 for a decent welder, then you need tanks, wire, gloves, mask, 200v if you dont (which i didnt). etc. then after you have it, you still arent a welding expert.
hi flow is ridicliously awesome. im seriously livid i thought i had to turn my car into a race car to fit a turbo and such. i wish marko was around a year ago. ******* hahaha.
Old Oct 5, 2005 | 03:06 PM
black_z's Avatar
Yes I can use a welder, I have access to migs, and tig welders and pretty much any tool imaginable.
Old Oct 5, 2005 | 03:20 PM
JRL96TA's Avatar
Originally Posted by black_z
Turbo-1200
Wastegate-400
BOV-250
FMIC-500
It all depends on what parts you wanna use. The MP T70 can be had for about $650. A Turbosmart WG or Deltagate can be had for about $250. There is no way that steel tubing should cost $500 especially without building headers. More like $250. That's already ~1k less. However a premade kit saves alot of time and hassle.
Old Oct 5, 2005 | 04:05 PM
smokinHawk's Avatar
id get the high-flo while the price is rediculously low. with 321 and all
hopefully it will be a while before they realize the price is to low and raise it.
so get it while you can, i dont think you can build one yourself cheaper
Old Oct 5, 2005 | 05:29 PM
black_z's Avatar
The thing is im low on cash right now (school) and I am just going to start collecting parts, and hopefully tackle the install next winter (06-07) Or I could just start saving now, and buy parts of the fuel system and hopefully have enough next winter. Its not possible for me to drop 4-5K right now. Im just kind of trying to figure out what I want to do, if its realistically going to cost 4000 for me to duplicate the parts that Hiflow is offering, its not reallly worth it.
Old Oct 5, 2005 | 05:30 PM
black_z's Avatar
MP T70? What company makes that? Do you happen to know how much power potential that turbo has for a 346?
Old Oct 5, 2005 | 06:35 PM
SuperZ's Avatar
I finished my homemade kita few weeks ago and although it took more money than I had hoped I still managed to spend on my forged motor and complete turbo system about what most turbo kits cost alone.Mine uses 2 6.0 manifolds facing forward a obx intercooler and a 76mm GT42 turbo.
Old Oct 5, 2005 | 06:56 PM
black_z's Avatar
What size intercooler did you get, or what part number? Im guessing you drive a camaro, do you have pics of your setup?
Old Oct 5, 2005 | 11:00 PM
JETmn's Avatar
I can get you some good deals on piping. Don't mess with mild steel either, I can get 304 stainless pretty cheap. Send me a PM if you want more details.
Old Oct 5, 2005 | 11:14 PM
black_z's Avatar
I will keep you in mind when im ready to buy and start fitting the piping. You post on the local boards as Jet dont you?
Old Oct 5, 2005 | 11:53 PM
JETmn's Avatar
Yep, you are on mnracing, right?
Old Oct 6, 2005 | 05:34 AM
smokinHawk's Avatar
if you can afford the hot parts id try for those, cause building your own will cost just about as much, plus youll need a welder.
but if you cant afford your cant afford,
what i always say take your intial estimate on how things are going to cost then double it, you might have enough then.
Old Oct 6, 2005 | 07:43 AM
Hawkcmc's Avatar
They are asking $2300 for the hot parts, that seems a little high, especially if he doesnt mind ditching the AC to do it with the manifolds. The kit looks pretty cool and $4300 for the whole kit is not expensive at all, but the hot parts for $2300 seems a little high to me. Even though I understand that a lot of research has gone into this and its pretty much the only tubular kit that does not do away with accesories. I still feel that it can be done for less than that.
CMC
Old Oct 6, 2005 | 07:57 AM
JRL96TA's Avatar
The Turbo is made by MasterPower hence the MP. It's probably the best bang for the buck turbo out there right now. That turbo will support 600hp on a 346. Check it out http://www.forcedinductions.com/productsMP.htm
Old Oct 6, 2005 | 08:06 AM
smokinHawk's Avatar
CMC
you thought wrong, ever price 321 parts for a set up, materials alone would be well over $1000, then you got vband clamps, those arnt cheap either.
i think piping cost of my kit in aluminzed came to about $1k with the vbands, and the vbands i used were cheap ones
dont forget the price of the welder you would have to buy if you built it yourself, you can get away with a $500 mig if your not doing aluminum, but my tig i got that can do aluminum was $1700.
plus you save yourself the headache of laying a kit out, i enjoyed building my own but it definatly was a headache.
with all that considering and being in 321 thats a dang good price, i suspect it wont last for long as they will find out they would be loosing money.
Old Oct 6, 2005 | 08:18 AM
SUPER DAVES Z's Avatar
[QUOTE=Hawkcmcits pretty much the only tubular kit that does not do away with accesories. [/QUOTE]
PTK's kit and the old Phamspeed kit have turbular manifolds and also keeps all accesories.
Old Oct 6, 2005 | 08:30 AM
RealQuick's Avatar
That turbo already supported 700rwhp on a local MA vehicle...Purevil's old sts setup.
Old Oct 6, 2005 | 09:05 AM
LSONE's Avatar
but pham/gzm run their pipes under the k-member, and PTK is, well, ridiculously priced. IMO, there really isn't a better choice out there right now than Hi-Flo.
Old Oct 6, 2005 | 09:09 AM
Hawkcmc's Avatar
Sorry if I upset you SmokinHawk, that wasnt my intention. I was just stating my thoughts. Black_z almost everyone of these threads I have read have stated that it will cost AT LEAST 4 grand to get the kit done. I plan on attempting it this winter using mild steel Bends, OBX intercooler, and a MP T70. So you are not the only one with this idea. I do plan on making my own manifolds because I would like to keep the AC if possible. So just keep researching and learn what you can.
