New BLOCK and HEADS from World Products !!!
Old Oct 6, 2005 | 08:42 PM
  #41
Reckless's Avatar
Super Moderator
Originally Posted by BlwnTA
We'll be deciding on our combo in the spring
Oh ****, now another Ohio guy getting the fever!
Old Oct 6, 2005 | 08:59 PM
  #42
2001WS6Vert's Avatar
Their probably going to tack a weight penalty on if you run it.
Old Oct 6, 2005 | 10:26 PM
  #43
nascar75's Avatar
why would they theres not much difference between running the ls1 block and this block. that is besides the fact that this block is a hell of a lot stronger.
Old Oct 7, 2005 | 10:15 PM
  #44
BlwnTA's Avatar
7 Second Club
The fever escalated to a sickness along time ago!
We'd post pics but Mike Brown and Steve Turley taught us along time ago that we are not allowed to share!
We will evaluate all our options, Worlds, LS1 Iron, LS2, etc when the time comes. Head lifting is an obvious problem but power from current set-ups not making it to the ground effectively is also a problem.
Old Oct 8, 2005 | 07:40 AM
  #45
sr71's Avatar
sbf's only have 4 headbolts per cyl and they make some incredible numbers with huge boost numbers without pushing water. why can't a lsx do the same???
Old Oct 8, 2005 | 07:49 AM
  #46
Paulz2820's Avatar
3 or 4 thousand horsepower on an aluminum block = its gonna melt
Old Oct 17, 2005 | 08:49 AM
  #47
Wet 1's Avatar
Default Update: It keeps getting better!
There was some misinformation in my original post (sorry). Here are the correct specs:
- 9.24" and 9.8" deck heights. (9.24 is stock)
- Will swing a 4.250" crank
- 6 bolts per cylinder (yes six!), extra bolts are at 12 and 6 o'clock.
- The WP block or heads can be used with non world heads or blocks.
- The WP block has a priority main oiling system (GM's does not). That is why they have to run such high oil pressures... The thing that needs the oil the most, gets it last (crankshaft).
- The heads will be LS-1 or LS-7/C5-R Combo (LS-7 intake C5-R Exhaust).
I'll pass any further info as I get it.
This is going to be the cat's azz!
Old Oct 17, 2005 | 09:08 AM
  #48
Project GatTagO's Avatar
Top Fuel dragsters use CNC billet aluminum blocks. They make 6000-7000 HP and the block do no melt. THey break a bunch of other things, but blocks generally do not fail unless a rod goes through the side.
Andrew
Old Oct 17, 2005 | 10:32 AM
  #49
NumberOneSled's Avatar
What kind of Bore will you be able to get with this block?
Old Oct 17, 2005 | 11:08 AM
  #50
RyanJ's Avatar
SSU Moderator
Now THAT makes sense now. Good job World Products. I'd like to know how much meat is between the cyliders on a bore greater than 4.125".
Old Oct 17, 2005 | 12:23 PM
  #51
1997 vet's Avatar
The LSx and a SBC have the same bore spacing. WP SBC can be bored out to 4.250. Were talking 482cid with a 4.25 stroke.
Old Oct 17, 2005 | 01:20 PM
  #52
99SS-T's Avatar
6 Bolts a cylinder.Taht is awesome. Should hold teh heads down with 50* of timing and 87 octane lol.
John
Old Oct 17, 2005 | 05:15 PM
  #53
smokinHawk's Avatar
4.25 bore spacing for real?
6 bolts per head
im definatlly going to have to get a second job to get one.
Old Oct 17, 2005 | 05:21 PM
  #54
69firebird's Avatar
that is going to be awsome if its all true.
can you imangine a 482 with a T106 on it, making like 2krwhp
the ohio boys cant handle the power they have now on some tracks, **** hows it going to end up after this.
Old Oct 17, 2005 | 05:53 PM
  #55
rons 00z's Avatar
yeah what is their secret?
Old Oct 17, 2005 | 06:18 PM
  #56
69firebird's Avatar
I am not sure but im think its fairy dust.
also thier dart blocks have more bolts too
Old Oct 17, 2005 | 07:49 PM
  #57
GrnDragon's Avatar
Actually the max bore for the World Aluminum Small Block is 4.155" not 4.25"
http://www.worldcastings.com/docs/05_cat_pg6.pdf
Old Oct 17, 2005 | 07:55 PM
  #58
1997 vet's Avatar
The max bore for their cast iron block is 4.250. Look at their 454ci sbc.
Old Oct 18, 2005 | 12:28 AM
  #59
JETmn's Avatar
Wow, the taller deck height sure will help out the rod ratio's! 4.125" bore, stock stroke and you are looking at 388 cubes and able to rev to the moon! I likes!!
Old Oct 18, 2005 | 01:28 AM
  #60
jlm44's Avatar
I'm in love!!!!
