New BLOCK and HEADS from World Products !!!
Old Oct 18, 2005 | 05:20 AM
  #61
smokinHawk's Avatar
Originally Posted by 1997 vet
The max bore for their cast iron block is 4.250. Look at their 454ci sbc.
that makes a bit more since, im guessing the max bore for the aluminum will be 4.15, maybe 4.16
a 390 borere would work great for a turbo or a 417 (3.9 stroke)
Old Oct 18, 2005 | 08:53 AM
  #62
Mike Norris's Avatar
Hey All,
I posted a reply in a similar thread in the Internal area which i have cut and pasted here. They had also brought up cylinder heads and passing this info along also.
Hey All,
A little more info for you. There is a possibility of a World Products block at SEMA with coolant jackets in them. Proposed ship date of the first prduction blocks will be 2/06 and quite a few orders are placed at this time. A World Products head will be there also, but a solid non-jacketed version for show. Chamber sizes are proposed at 58cc and 68cc options.
The Dart heads will be available in 205cc and 225cc runners as cast. Prelim 225cc tests show in the 310-315ish CFM as cast.
There will also be two other companies (not Edelbrock or All-Pro) releasing castings and assemblies not only in 205cc & 225CC versions, but also 240cc and 265cc in the LS1/6 style heads and also LS7/C5R styles. Intakes are also being developed as a complet package.
Bear in mind that with all of the aggressive packages there will be some differences. Though they will be bolt on in relation to cylinder head to block and intake to cylinder head, there will be some definite changes in the valve train area to keep geometry proper. At this time there are some folks using .200" long valves and related parts. But with some of these heads, .500" and .600" long valves will be required as well as different pushrod lengths from the norm. Some have higher valve cover sealing areas to clear most roller rockers and some are even offset. I mention this as often folks think a bolt-on is always simple and in this case there is a lot to consider in one of these aggressive head swaps. Nothing outrageous, just different then usual.
It will be an interesting trade show season to say the least. Hope this info helps. Thanks.
Mike Norris
Old Oct 18, 2005 | 07:44 PM
  #63
Wet 1's Avatar
Default Lots Of Details !!!
Okay guys, here's the 411 on the WP block and heads...
"Warhawk" Block:
- 357 T6 Aircraft aluminum.
- 4.00 Or 4.125 bore with .100 thick dry sleeves backed by .300+ aluminum.
- Crank case will accept 4.250 stroke with out modifications.
- Priority main oiling circuit (unlike GM that feeds lifters 1st cam 2nd crank last.
- Extra wide crankcase (like box pan) to control windage.
- Available 2 deck heights 9.240 and 9.800.
- Cam bores can be machined to 60mm.
- Available with both late LS1 motor mounts and early S.B. Chevy mounts.
- Provision for (Do not have to use) 2 extra head studs per cylinder for blown applications.
- Billet Main caps C5R style with ARP Studs.
- Can be wet or dry sump. Scavenge pick up at rear of block.
- All standard GM parts bolt on.
- $3799.99 retail price is 35% less then C5R.
086210
9.240 X 3.990, Billet Splayed Main Caps
$3,799.99
086220
9.240 X 4.115, Billet Splayed Main Caps
$3,799.99
086230
9.800 X 4.115, Billet Splayed Main caps
$3,999.99
WARHAWK Aluminum Cylinder Heads Replaces LS 1 thru 6
- 355T6 Aircraft aluminum.
- 15 degree valve angles.
- 220cc intake runner size.
- 2.080 X 1.600 X 5/16 valve size.
- 58cc or 68cc chambers.
- .750 thick deck.
- Uses standard LS1 valve train components.
025150
58cc Bare Casting
$649.99
025150-1
58cc Mech/Hyd.Roller 1.250"Dual Spring Assem.
$754.99
025150-2
58cc Solid Roller 1.437" Dual Spring Assem.
$879.99
025150-3
58cc Solid Roller 1.550" Dual Spring Assem.
$984.99
025250
68cc Bare Casting
$649.99
025251-1
68cc Mech/Hyd.Roller 1.250"Dual Spring Assem.
$754.99
025252-2
68cc Solid Roller 1.437" Dual Spring Assem.
$879.99
025252-3
68cc Solid Roller 1.550" Dual Spring Assem.
$984.99
The Warhawk 7X 12 degree aluminum cylinder head is the preferred alternative for LS7 and C5R.
- 12 degree valve angles.
- 255cc intake runner size.
- 2.200 X 1.625 X 5/16 valve size.
- 62cc C5R style chamber.
- LS7 intake manifold opening size and bolt pattern.
- C5R style exhaust port.
- Provision for 2 extra head studs per cylinder.
- .750 thick deck.
- Uses Standard LS7 Valve train components.
025350
62cc Bare Casting
$799.99
025350-2
62cc Mech/Hyd.Roller 1.437"Dual Spring Assem.
$1,029.99
025350-3
62cc Solid Roller 1.550" Dual Spring Assem.
$1,134.99
I hope this answers more questions. All prices are retail. I have not heard the max bore. 4.250" is the max bore on the iron block, not the aluminum. Given the cylinder wall thickness, I'm not sure you'd want to go to much past 4.125"... still, this still gives 454 ci capicaty.
I'll let you know if I hear anything else.
Old Oct 18, 2005 | 09:05 PM
  #64
jlm44's Avatar
So what all will be inner changeble? anything?
Old Oct 18, 2005 | 11:06 PM
  #65
JETmn's Avatar
Absolutely bad ***! This makes my block decision a no brainer. Boost junkies are going to love this!
Old Oct 18, 2005 | 11:18 PM
  #66
jlm44's Avatar
I definitely agree that this is bad *** but I would like to know what is innerchangeable and why they didn't go with an ls1 style bottom end such as 6 main caps?
Old Oct 19, 2005 | 02:56 AM
  #67
smokinHawk's Avatar
wish the heads started out bigger then 68cc's or 62cc's for the 12*
with a 4.125 bore the CR will be high.
Old Oct 19, 2005 | 12:13 PM
  #68
jlm44's Avatar
I was thinking the same thing last night before I went to bed.
Old Oct 20, 2005 | 01:28 PM
  #69
JETmn's Avatar
Use dished pistons.
Old Oct 20, 2005 | 03:23 PM
  #70
smokinHawk's Avatar
Originally Posted by JETmn
Use dished pistons.
theyd have to be dished quite a bit can they dish them to 28cc's that would give a 8.3:1 CR on a stock stroke and stock gasket thickness
youd need 36cc dish to get it to 8.3:1 with a 3.9" stroke
a 39cc dish to get it to 8.3:1 with a 4" stroke
i think you need to take some out of the head.
Old Nov 3, 2005 | 08:15 AM
  #71
Wet 1's Avatar
Just to keep the thread interesting, I thought I'd spice things up with some pics that Vtespeed (thanks!) took from SMEA...
Old Nov 3, 2005 | 09:42 AM
  #72
smokinHawk's Avatar
awsome! the heads will come 72cc chambers!
the heads say they have C5R intake runners any info if it would take the stadard ls1-6 style intakes?
any clearer pictures on the info sheets, my eyes hurt from trying to read those.
i didnt see the biggest bore the block will take, i think i made out it will take up to a 4.2" stroke, then calculated that with a 4.125 bore. 45X cubes.
Old Nov 3, 2005 | 09:55 AM
  #73
Camaro_Zach's Avatar
block/heads dont look done to me....if they dont have a casting with holes drilled and threaded for SEMA i dont think its commin out in the next month or two...could be wrong though
but man does it look nice thus far.
Old Nov 3, 2005 | 10:39 AM
  #74
Mr_president's Avatar
uhh this is kinda a dum question im new to builing whole engines but that block is bear corect no piston and no crank ect...
Old Nov 3, 2005 | 11:42 AM
  #75
smokinHawk's Avatar
thats correct, you get the block then put the assembly pieces in
reading the heads more i think it says it has an LS7 intake partern, can an ls6 style bolt up to that? id hope to run the carb intake.
Old Nov 3, 2005 | 11:52 AM
  #76
Brandon Boomhauer's Avatar
for those of you who can't read the info...
LS7X
12 Degree Heads
*Provisions for 2 extra head studs per cylinder
*Huge 255cc intake runners,
64cc & 72cc C5R chambers
*Uses Big 2.200" intake and
1.625" exhaust valve (5/16")
*Valve spring seats can safely
handle big 1-5/8" o.d. springs
*12 Degree valve angle - uses
standard LS7 components
*LS7 intake manifold opening
sie and bolt pattern; C5R
style exhaust ports.
Old Nov 3, 2005 | 11:56 AM
  #77
RyanJ's Avatar
SSU Moderator
its LS7 intake and valvetrain stuff. Maybe an SB2 will work. I heard somewhere the SB2.2 single plane intake ports line up with C5R stuff.
Old Nov 3, 2005 | 11:58 AM
  #78
now the block stuff
LS7X
Aluminum Block
*Equipped with both LS1 and
standard SBC motor mounts
*Priority Main oiling feeds crank
first and top-end last
*Choice of 9.240" and 9.800"
deck heights
*Cam bores can be machined up to 60mm
*Provisions for two extra main
studs per cylinder
*Crankcase accepts 4.250"
stroke crank - provies big
454 c.i.d. with a 4.125" bore
edit: saw other info above.
Just noted this for those ofyou trying to read the spec sheets in pics.
Old Nov 3, 2005 | 12:56 PM
  #79
smokinHawk's Avatar
ah thanks!
im curious to what intakes will be availible
Old Nov 4, 2005 | 12:58 PM
  #80
1FST99Z's Avatar
I will proly go and by another fbody or ybody to stuff that motor into. that is going to be a nice piece. cant wait for it
By Brett Foote | 2026-06-04 05:00:17
