blower guys ...................help
Old Jul 20, 2002 | 06:33 PM
blkws6pon's Avatar
Default blower guys ...................help
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> went to the track.........not the times i expected...11.8 was my best and 12.1 was my worst...........it was about 85 and muggy. i run at quaker city in ohio. 1.84 60 ft time...92.5 in 1/8 mile...11.87in 1/4 mile at 114mph. i was thinking 10:90s with my set up........is it the humidity........can it make tha much of a difrence?
Old Jul 20, 2002 | 07:03 PM
MelloYellow's Avatar
Default Re: blower guys ...................help
How Rich? Timing? Losing any boost/slippage? This run on ET's?
Old Jul 21, 2002 | 12:21 AM
Blackbird's Avatar
somethings wrong
you should be running 124mph not 114
what does a/f look like? how much boost is registering?
any knock retard?
etc....
Old Jul 21, 2002 | 12:24 AM
blkws6pon's Avatar
just had my programming done......no belt slippage, this run was with et streets....and this is 2 day after having the car dyno'd at almost 550 rwhp and 550wrtq.?
Old Jul 21, 2002 | 12:27 AM
blkws6pon's Avatar
i did notice since the ati install my temp is around 210--220 degrees....is that ok?
Old Jul 21, 2002 | 03:45 AM
Black LS1 T/A's Avatar
Moderator
What's your elevation in OHIO?
Old Jul 21, 2002 | 03:51 AM
Moderator
I just checked... supposed to be about 850. Shouldn't be a huge factor.
For this time of year, that temp with the ATI sounds probable to me.
Muggy days have sapped my ET's anywhere from .2 to .4 in the 8th mile. <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
With that HP on the dyno, it would SEEM your A/F should be dialed in.
You've got the gearing and stall to put it there... I don't understand it.
Is it possible that between the dyno and your run that something went awry? Did you REALLY check that your boost level was 10 PSI at the track. I have had 10 PSI, the belt stretched, and my next run at the track I was nearly a half second slower in the quarter. I was watching Fuel Pressure, but for some reason didn't check my peak boost levels until after 2 or 3 runs. A re-tightened belt solved that.
Double-check everything is the same from when you dyno'd. I'd consider re-dynoing locally, if you can't pinpoint what's going on.
<small>[ July 21, 2002, 03:57 AM: Message edited by: Black LS1 T/A ]</small>
Old Jul 21, 2002 | 04:21 PM
blkws6pon's Avatar
thanx i will check more carefully at my boost level when going down track...but i m pretty sure it was at ten..when it shifts it does drop then climbs....but that isnormal i would think.i sure would like to run it on a cool day or evening.
Old Jul 21, 2002 | 04:22 PM
blkws6pon's Avatar
