cometic MLS gaskets
Old Oct 6, 2005 | 08:14 PM
30th t/a's Avatar
Default cometic MLS gaskets
wheres the best place to get them? also should i get 3 layer or 4 layer?
Old Oct 6, 2005 | 08:26 PM
V8_DSM_V8again's Avatar
I am partial to the SCI ICS titan...
The straightness and finish requirements are the same..
If you get a cometic get the cometic HP..
Thickness depends on your head CC, pistons and your desired compression ratio goal.
Old Oct 6, 2005 | 09:10 PM
ABeasst's Avatar
I've had alot of seeping problems w/ cometics so now I'm gonna try the GM MLS plus they are only $20/each
Old Oct 6, 2005 | 10:43 PM
KissMySSo1's Avatar
titan all the way
Old Oct 7, 2005 | 06:21 AM
2001WS6Vert's Avatar
You can buy direct from Cometic. That's what I did.
Old Oct 7, 2005 | 12:57 PM
30th t/a's Avatar
where are you guys finding these GM MLS, i called the dealers and they have no clue on what im talking about. i also called SDCE and they could not help me out either.
Old Oct 7, 2005 | 04:08 PM
ABeasst's Avatar
P/N: 12589226 get them from gmpartsdirect.com
Old Oct 7, 2005 | 04:34 PM
JETmn's Avatar
Yes, if you get the cometic get the HP. The standard MLS ones aren't that good.
Old Oct 7, 2005 | 04:42 PM
blu00rdstr's Avatar
I went from Cometic (leaked eventually) to GM MLS.
