More than 17psi?
Old Oct 7, 2005 | 11:10 AM
Shane_G's Avatar
Default More than 17psi?
I've heard from a couple different people that the heads start lifting after 17psi on boosted applications. Is there any truth to this? I see a couple people on here running more than 17 and they don't seem to have a problem.
Thanks.
Old Oct 7, 2005 | 11:16 AM
NA$TY-TA's Avatar
Its in the tune man........ i plan on running more then that........
Old Oct 7, 2005 | 12:22 PM
bd2bonez06's Avatar
Thanks.
Heres a bump for you. I am interested in this also, and also how long are they lasting with this much boost
Old Oct 7, 2005 | 01:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My car has hit anywhere from 17 to 21.5 psi.
I use A1 head studs.
Old Oct 7, 2005 | 02:25 PM
vtanju's Avatar
i am running 1.3bars, and no problems yet.........
Old Oct 7, 2005 | 03:36 PM
RyanJ's Avatar
SSU Moderator
yes...exactly at 17.1psi...on any combo, regardless of tune, air flow, and backpressure. What sense does that make?
Detonation makes heads "lift." Although it seems the whole notion of the word LIFT is a misnomer. At worst you put INTENSE pressure/heat around the head and warp the contact surface, but I don't know if anyone (except for Rob at QMP) actually having a head fail and lift itself off the surface of the block, trashing the head bolt/stud area. With AFR/AllPro/Dart heads and their thicker surfaces, plus headstuds, I don't see that happening again. Now, hot spots due to detonation will put holes in any combo.
Old Oct 7, 2005 | 03:46 PM
Got Me SOM's Avatar
i wouldn't say 'x' amount of boost lifts heads, its more based on the actual cylindrical pressure that lifts the heads and causing gaskets to pop out. There is a theoretical max threshold that the heads will stay down , even with a good tune. w2w is a perfect example with their 6 sec car. Their car lifted the heads but they are pushing what almost 1600 hp, lol.
Old Oct 7, 2005 | 04:00 PM
RyanJ's Avatar
SSU Moderator
yeah see that's the thing though...1900hp, 30+ psi FROM TWO 80MM TURBO's and the heads are lifting on every pass...enough that they use a BOV on the cooling system. 17psi or 30psi from say a single 76 is a little different than the "same" amount of boost from twin 80's or twin 60's or whatever. Its air...boost is resistance. Its not a real good indicator of the power going in w/o quoting the combo.
Old Oct 7, 2005 | 04:03 PM
Slowhawk's Avatar
LS1Tech Sponsor
Cylinder pressure and the tune lift's the heads.Our shop race car lift's the heads every racing event because we run high compression,high boost.No big deal changing the gaskets
