Phamspeed finally done!!!!
1. My downpipe is bottoms out ALOT. How much power would I lose if I flattened the DP a little? Did anyone else have this problem?
2. Since I had to move the alternator to the passenger side, the oil cap doesnt fit, I need to find a way to cover that whole somewhere. Where can I get the smallest cap possible to go straight into the valve cover? Any sugestions?
Besides that it sounds really wicked, and its a blast to drive, but I really cant get on it b/c it gets oil all over the place
PLease I need some more help!!!! And thanks to all the guys that answered when I posted a problem, I couldnt have finished w/o this forum.
just undo the one coil back swing it out of the way tighten down your oil cap swing it back over and tighten it down...
or get one of the valve cover breathers that screw right in there..
speed inc sells nice one that im using also will help vent pressure
As far as the DP goes you woudl have to do ALOT of flattening to make any sort of hieght difference. If you jsut flatten it about a hammers head width you would only get about a half inch outtta. it. Adn that aint gonan make a bit of difference. If you go and flatten it alot you will have a flow issue. Is your car lowered? If not then you should be ok. I dont have mine lowered and i have only hit it a hand full of times over the summer. GL man
John
You may want to hook up a gauge and see what boost you're really pushing.but I think i fix the oil cap thing by getting the stock cap and putting it on a grinder and made it small and srewed in.
took the intake pipe apart and found some oil from the turbo oil line. Hopefully its left over from before, Ive added a scavenge pump and a line restrictor and that should be enough.
On a side note, is it just me or does phamspeeds website not work? It is www.phamspeed.com correct? Nothing ever comes up, unless there is another page or that's the wrong address.
As for your smoking problem
How do you have your oil return line setup?
Hows your PCV valve setup?
