Incon BOV Question
Old Aug 22, 2002 | 03:25 PM
Phate's Avatar
Default Incon BOV Question
For those of you with Incon kits, has anyone had a BOV flange welded on the '***' pipe?
I am thinking of getting a BOV and I wanted to know what brand/type you went with. Also, what material is the '***' pipe made out of?
Thanks,
Scott
Old Aug 22, 2002 | 04:03 PM
Mark C's Avatar
Default Re: Incon BOV Question
No BOV, but I believe that the material is the cast version of 6061-T6 aluminium.
Old Aug 22, 2002 | 04:34 PM
Phate's Avatar
Thanks Mark!
Old Aug 22, 2002 | 07:28 PM
red ws6 99's Avatar
It should not be made of 6061-T6 since its not used for casting. Probably a 300 series aluminum.
Gary
Old Aug 22, 2002 | 09:37 PM
Phate's Avatar
But it is aluminum, correct? I want to get a flange welded to the '***' pipe for the BOV.
Thanks,
Scott
Old Aug 23, 2002 | 01:34 PM
Phate's Avatar
Cool,
Any recommendations on a good low-boost (4-12 psi) BOV?
I am thinking of a Greddy Type S based on what I have read and what the Mustang TT guys are running.
Thanks,
Scott
Old Aug 24, 2002 | 12:05 AM
red ws6 99's Avatar
Yes it is aluminum, just tell them its cast they will get the right welding rod to work with it.
Gary
Old Aug 24, 2002 | 10:34 AM
red ws6 99's Avatar
IF the BOV is used for import cars then you will want something that is like a boost range up from the boost range you are running. We flow a lot more a the same boost level than an import so a race sized one would probably work well. I have no looked at the specs on them so I dont have any real recommendations.
Gary
Old Aug 26, 2002 | 10:40 AM
Mark C's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by red ws6 99:
<strong>It should not be made of 6061-T6 since its not used for casting. Probably a 300 series aluminum.
Gary</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I know, I know. I was just too lazy to look up the cast designation, but the chemistry is the same as 6061. What is it, something like 356?
Old Aug 27, 2002 | 12:03 AM
red ws6 99's Avatar
Just keeping you on your toes <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Gary
<small>[ August 26, 2002, 12:03 PM: Message edited by: red ws6 99 ]</small>
