Oil blowing out pcv valve
This is what I have:
1998 Camaro SS
Forged 6 liter
Stock crank
Eagle rods
Diamond forged pistons
Comp cams turbo cam
LS6 intake
65lbs injectors
GT70 STS Turbo
There's more but you get the idea.
I've been driving it pretty easy and haven't been beating on it.
The other day I drove the car 120 miles to see some family and took my brother in-law for a ride. I got on it pretty hard through 1st and 2nd gear.
I left it in drive and let the computer shift it. Just your normal 0 to 80 or so run.
My brother in law looked behind us after the run and said there was allot of smoke I didn't think anything of it because the tires were spinning all the way to 80mph and thought it was tire smoke.
On the way home later that day I merged into traffic on the highway and stepped on it a little to get up to speed. I looked behind me and there was a cloud of blue (oil) smoke. I pulled over and popped the hood. Oil was all over the right side header from the pcv valve. I checked the oil level and it was still full. The car was still running perfect, no noise, no loss in power and it was running cool. I drove the car home 120 miles without any problems. I babied it and stayed out of the boost. It ran cool and didn't blow any more oil out.
The tune on the car is very conservative and has almost no knock. It has forged pistons and I'm only running 10lbs of boost. I haven’t done a leak down test yet but plan on it next week some time to see if a piston broke.
Anybody have any ideas? I can't believe I broke a piston considering their forged and the tune is right on. With only 10 lbs of boost the head gaskets should be ok.
I've heard crank case pressure is a problem with the LS1 and forced induction so I hope it's just the pcv system. I just don't understand how its been running so well and until now hasn't blown any oil out. Could the pcv valve be plugged or something? I looked at it and there is oil all over it.
Any ideas as to what could cause this??
Thanks guys
Jon
I was told if I vent the valve cover with a breather cap it will not allow the pcv to work properly. Is that a smart way to do this?
Thanks for you help,
Jon
if your problem just came up really fast then you may have hurt something.
I plan on hooking up the kit and tuning it for street driving without getting into any boost for the first 500 miles. Then I will tune it for WOT and see what happens.
