Big HP guys what cooling system?
Are you running yours as pusher fans? What fans are you running?
New setup is a single Griffin Radiator (smaller then stock) with a single 16" SPAL puller fan. Stock water pump..... and stock thermo again.......
Kyle
Also the car smokes alot from the exhaust when I start it or after I give it any boost. I opened the intake pipes and it had some oil on the inside. Blown turbo seals do to much oil preasure?
As for the oil problem I asked before and don't think you answered back? Hows your oil return line look? where did you tap the oil pan? You might need a bigger oil return line or you might of tapped it in a bad location. Maybe you need to put a oil restrictor in your feed line. You PCV setup might be wrong>
1) GET A SHEET OF PAPER, PAPER TOWEL, LENGTH OF TISSUE...ETC
2) TURN THE CAR ON, LET THE FANS KICK ON, OPEN HOOD
3) GET THE SHEET OF PAPER OR OTHER FORM OF PAPER PRODUCT, HOLD IT INFRONT OF THE FANS.
4) IF THE FANS SUCK THE PAPER TOWARDS THE RADIATOR, THE FANS ARE WIRED RIGHT, IF THE FANS BLOW THE PAPER BACK TOWARDS YOU, THEY ARE WIRED WRONG.
PUSHER FANS PUSH, IF THEY ARE WIRED WRONG THEY WILL PULL AIR TOWARDS THE HOODLATCH.
ALSO....
Get some -40 below engine coolant additive, follow the instructions on the back of the can to a T
That will help a lot, I run it and my car stays cool.
ANOTHER VERY IMPORTANT STEP TO RUNNING FANS IN FRONT OF THE RADIATOR.
HAVE YOUR FANS COME ON @168 degrees, this is done via HPT, EFILive, LS1edit.
That will give your car a nice head start to keeping cool with pusher fans.
I've run the FAL's for about 5 years with no problems, with the turbo on the car, the cooling got a lil touchy but I added in the cooling treatment and all is well.
Next thing to do to keep the car cool would require relocating the radiator, and adding in a large single fan, like Slowhawk and quite a few others have done.
J
ALSO....
J
word Jer word......
SO you can see coolant coming out of the block somewhere? IF you can definately get it back to the shop so they can fix the problem. I'd do it myself, so you can be sure that its done right. If it overheated bad enough you could have warped the heads.
With the oil in the pipes...it'll take some time to get it out especially if you had a nice problem with the turbo blowing oil into the DP. I had to remove my DP and my "s" pipe that I made to connect the catback to the DP to get all the oil out. I used 3 cans of brake cleaner to clean the oil out of em. Been fine since.
I had quite a bit of oil move through the turbo into the DP, but since I fixed the problem the turbo has been fine, no blown seals..pretty sure yours is fine too.
Post a nice clear pic of your drain line please. You shouldn't be having any problems getting oil out of the turbo especially with a scavange pump...unless the scavange pump isn't working right.
How high is your pan drilled? Post a clear pic of that too.
As for your oil thats a tuff one to figure out if you are running a pump setup. When it happened did you take off all the IC pipes and clean them out? Also hows your PCV valve setup, are you running a catch can with a check valve in place?
I would try all this stuff first before taking it to a shop for the head gasket. Can we get a picture of your oil line setup?
i got stock fans on at 180* stock radiator, 160 stat
