whats the max boost for a 346ci?
have arp studs, cometic gaskets. 6.0 heads.
6.0 heads, forged pistons, billet rods, stock crank, 8.7:1 CR
my bearing failure wasn't related to the power levels, still diagnosing the failure.
Unless Rob decided to cut the reported flow with whatever method, trust me had a nice flatlined maf at that power level.
That is not a serious issue though and is one of the least of my worries.
There are many ways to add more fuel without using the maf once it becomes static.
Steve
Max cylinder pressure before stuff goes wrong maybe. You could run no timing, and crazy amounts of boost, and not have an issue. Max boost on pumpgas or 118 octane racing gas?
Steven
<strong>havent found the max boost yet on my set up yet, but with 9.0:1 CR, 348ci forged rods pistons i run 10psi on 94 octane with less the 0.9 degrees knock.
have arp studs, cometic gaskets. 6.0 heads.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Smokin:
How much timing are you running again?
TIA
11psi by 6000rpm - Ported G-trim Vortech, 346ci 9.4-1 compression.
22 degrees timing , 93 octane with 16gph 60/40mix-3 nozzle alcohol/water injection and no intercooler.No knock retard.
This is a brand new combo and so far it's making fantastic power without any issues.
Plugs dry as a bone,no coolant temp rise.
Started at a very rich 10.2-1 and ended at 11.2-1 A-F. Had to dial back the fuel quite a bit with the alky flowing.
About 60hp being supported by the alcohol and around a 100 degree drop in IAT.
This is going to be my street tune.
I really think if you can keep the iat way down, and keep away detonation you can run a lot of power without lifting the heads.
And thanks to KP for his wideband! Can't see ever trying to tune again without having one in the car.
Steve
IAT at around 122 before I began.
As a comparison,with my 5psi pulley and no water/alky flowing, it hit 147 degrees.
This was at 10psi.Without the system flowing, IAT would have been over 200.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">code:</font><hr /><pre style="font-size:x-small; font-family: monospace;">KNOCK,O2 B1S1,O2 B2S1,inj B1 ms,inj B2 ms,MAF lb/min,RPM,ADV°,IAT °F
0 903 872 3.46 3.46 4.28 1875 32 122
0 907 877 3.57 3.57 4.47 1925 32 122
0 907 864 3.6 3.6 4.63 1978 32 122
0 894 851 3.71 3.71 4.75 2012 32 122
0 903 864 3.62 3.62 4.82 2061 32 122
0 890 838 3.72 3.72 1.34 2099 27 122
0.53 920 890 10.6 10.6 15.8 1994 21.5 122
0.44 920 916 11.9 11.9 23 3159 24.5 122
0.44 938 920 14.3 14.3 39.4 4100 17.5 122
0.35 929 929 14.4 14.4 46.6 4665 18 122
0.35 933 929 15.4 15.4 51.8 5154 18 122
0.26 942 929 15.7 15.7 55.9 5416 17.5 122
0.26 938 924 16.1 16.1 62.1 5893 17.5 122
0.53 933 929 15.9 15.9 63.2 5995 17.5 122
0.53 942 929 16 16 56.7 5925 17.5 118
0.44 938 938 15.3 15.3 47.6 4887 17.5 118
0.44 951 938 14.6 14.6 40.5 4570 17.5 118
0.35 942 933 14.5 14.5 43.7 4507 18 118
0.35 951 933 14.5 14.5 41.1 4547 18 115
0.26 938 942 14.7 14.7 45.9 4647 18 115
0.26 942 938 14.8 14.8 44.6 4694 18 115
0.18 938 938 14.9 14.9 47.9 4782 18.5 111
0.18 938 938 15.2 15.2 49 4857 18.5 111
0.09 929 933 15.2 15.2 48.6 4899 19.5 108
0.09 942 929 15.1 15.1 51.3 4966 19.5 108
0 946 929 15.6 15.6 48.6 5017 19.5 108
0 938 933 15.4 15.4 53.5 5128 20 104
0 942 933 15.6 15.6 54.3 5172 20 104
0 924 929 16 16 53.5 5245 20.5 102
0 946 929 15.8 15.8 53.5 5334 20.5 102
0 938 924 15.9 15.9 55 5422 20.5 102
0 933 929 15.8 15.8 58.9 5505 20.5 102
0 938 920 16.1 16.1 57.9 5600 20.5 102
0 933 924 16.1 16.1 59.8 5687 20.5 102
0 942 920 16.1 16.1 63.2 5781 20.5 102
0 933 916 16.1 16.1 62 5847 20.5 102
0 924 916 16 16 62.1 5951 20.5 104
0 924 916 16.1 16.1 63.2 6002 20.5 104
0 920 916 16 16 63.2 6097 20 104
0 920 916 16 16 54.1 5617 20 104</pre><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<small>[ October 10, 2002, 09:42 AM: Message edited by: SJH ]</small>
i looked at a few of my logs and the MAF has reached 12222, whatever that means.
